Best connection for monitor to graphics card??
Post Date: 2018-06-04
Dboyce View Drop Down
  Quote Dboyce Quote  Post ReplyReply bullet Topic: Best connection for monitor to graphics card??
    Posted: 04 Jun 2018 at 5:52am
Looking for opinions on the best cable to connect your monitor to the graphics card. Currently im running a Dell ultra sharp monitor which is an okay monitor. Only 60hz refresh rate. I will soon be upgrading to a 144hz refresh rate monitor just wondering what everybody uses for connecetion cable?
Thanks
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 04 Jun 2018 at 7:18am
On my Dell Ultra Sharp at 1080p  I used the DVI port.  On my new !440p at 144 Hz I'm using the Display Port.
Big%20Smile
Edited by bprat22 - 04 Jun 2018 at 4:03pm
  Quote Cretae Quote  Post ReplyReply bullet Posted: 04 Jun 2018 at 8:09am
Some display port cables are only rated for 1080p at 60 Hz. Make sure you get ones that will carry the whole signal. Most times, I believe the monitor will come with fully certified cables.
  Quote Snaike Quote  Post ReplyReply bullet Posted: 04 Jun 2018 at 3:40pm
On my secondary 1080 I run the Display port, on the primary 1080 (both 60Hz) I run HDMI... And I'm keeping that when I can trade out for a 1440 (144Mz)
  Quote Cretae Quote  Post ReplyReply bullet Posted: 04 Jun 2018 at 4:59pm
From what I understand, you're going to be at least better off using DP for the higher res AND the higher refresh. Might be your current HDMI cable couldn't give you either one. And if you get G-sync, the newest HDMI cables won't optimize it or perhaps run it at all.
Again, best you use the cable that comes in the box, I'm thinkin'.
Edited by Cretae - 04 Jun 2018 at 5:01pm
Tomsal View Drop Down
  Quote Tomsal Quote  Post ReplyReply bullet Posted: 07 Jun 2018 at 5:44pm
I always go Display port personally and I've tried vga, dvi and hdmi. DP is my preferred, and afaik based on what I've read many sites agree that DP is the way to go particularly for gaming displays.
