Best CPU fan
Post Date: 2009-04-14
  Quote !ender_ Quote  Post ReplyReply bullet Topic: Best CPU fan
    Posted: 14 Apr 2009 at 11:22pm
asus maximus mobo
q6600 chip
looking for what you all think is the best standing heatsink on the market. my artic 7 has just gone bad on me, it was a very good performing fan IMO, kept me in the 30s with a beastly overclock
the way my case is built its vital to me that the fan be standing off the chip vertical and be blowing towards the BACK of the case. please keep this in mind when making suggestions
price is not important although under 100 would be nice
ShaneF187 View Drop Down
  Quote ShaneF187 Quote  Post ReplyReply bullet Posted: 15 Apr 2009 at 8:59pm
The Cooler Master V8 is one of the best CPU air coolers out. Just make sure that you have enough room in your case because that thing is HUGE!
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 15 Apr 2009 at 9:19pm
If you were happy with the cooling of your Ac7, then for 20 odd dollars including shipping, with pre-installed TIM, just get another one. They are about the easiest ones to install of all the aftermarket coolers.
Mezzeron View Drop Down
  Quote Mezzeron Quote  Post ReplyReply bullet Posted: 15 Apr 2009 at 9:43pm
The V8, thermalright TRUE are The Noctua fans are among the best out there.  All under $100.  I listed them in order of cheap to expensive
Clinton View Drop Down
  Quote Clinton Quote  Post ReplyReply bullet Posted: 16 Apr 2009 at 7:32pm
Is the Cooler Master V10 better than the V8? Doesn't look like it can move much air.
Kitijima View Drop Down
  Quote Kitijima Quote  Post ReplyReply bullet Posted: 26 Apr 2009 at 11:46pm
Based on MPC's review the V8 is better than the V10 with cooling.
One of my favourite hobbies is I like to procrastinate...O_o
Joshua View Drop Down
  Quote Joshua Quote  Post ReplyReply bullet Posted: 09 May 2009 at 2:27pm
I got water for my cpu. I was thinking about getting the v8, but I decided not to. I'm going to be pretty disappointed if they can't at least oc my i920 to 4.0. I've read people getting theirs to 3.6 stable on air alone. I had to spend 100 bucks on a 360 radiator as suggested by James. Not only that, the expensive frostbite cpu cooling system.
Edited by Joshua - 09 May 2009 at 2:31pm
This page was generated in 2.636719E-02 seconds.
