Best monitor for single GPU?
Post Date: 2009-07-19
biggmac101 View Drop Down
  Quote biggmac101 Quote  Post ReplyReply bullet Topic: Best monitor for single GPU?
    Posted: 19 Jul 2009 at 4:46pm
I was wondering if anyone could advise me on what kinds of things I should consider when purchasing a new monitor.  I put in an order for a new DS last Thursday, and I want to make sure I pick up a monitor that can make it look as good as possible on my budget (probably between $200-$300).  My DS will have a single Geforce GTX 285 2GB GPU.  What kind of monitor should I get for optimal resolution?  What brands are the best?  Does anyone have any suggested models I should buy?  This is the first PC I have ever bought, so I really do not know what I need to get the most out of my system.  Thanks for any help anyone can give me.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 19 Jul 2009 at 10:06pm
you should call then and change your GPU to a 275 896MB version and save your money, no matter if you have the 275 I mentioned or the 285 2GB version, they both perform the same, difference is like 4 fps, both those cards can run a 1600 x 1200 resolution with high settings in games, for higher then that you will 2 GPUs.
Edited by DST4ME - 19 Jul 2009 at 10:07pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Jul 2009 at 12:05am
I guess everybody else understood I was referring for games (hence the comment about 4fps), accept the person that needs to talk to his monitors otherwise everybody knows any card from past 2 years can run any any monitor practically
Edited by DST4ME - 20 Jul 2009 at 12:08am
  Quote biggmac101 Quote  Post ReplyReply bullet Posted: 20 Jul 2009 at 12:22am
Thanks for the help guys.  harleyman thanks for the link, that does look like a good monitor.  I know that any monitor will work, its just that I have read that if you get a monitor that is too big for your vid card you might get some small text at higher res, and I just want to avoid that if possible...but I guess for my budget I don't need to worry about getting one that is too big lol.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Jul 2009 at 2:59am
Unlike you on don't advise based on what I think and my singular experience, I advised based on real time tests, opinions are dime a doesn't, and how many times do I have to show you that sharing ram with CPU in these systems is like talking about a dime in respect to a million dollars, in other words sharing GPU ram with CPU means nothing and produces no big effect if any.
if on high settings (8x aa, 16x af) you are getting over 60fps, you are getting a quality picture aka smooth and fluid game play. anybody that knows the basics about gaming knows that much, and 30 fps is playable not completly smooth, 60 fps is completely smooth.
Just because your mommy still tucks you in, it does not mean everybody else is having the same thing, there you go thinking everything is like your own singular experience again
Edited by DST4ME - 20 Jul 2009 at 3:00am
RogerWIlco View Drop Down
  Quote RogerWIlco Quote  Post ReplyReply bullet Posted: 23 Jul 2009 at 10:04pm
Running a 32" 1900x1200 here on one 8800 GTX...works great!
DS Twister LITE
C2D E6750 2.66GHz
nVidia 680i Core 2 Quad
2GB DDR2 Corsair
1 TB HDD 7200 RPM
nVidia GeForce 8800GTX 768MB
850W Thermaltake
Razer DeathAdder
Razer Tarantula
Win7
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 24 Jul 2009 at 1:23am
what games are you running and are your settings on high? cause we are talking about 4x aa 16x af, or 8x aa 16x af.
This page was generated in 6.835938E-02 seconds.
