Best Thermal Compund - Grease? For CPU & GPU
Post Date: 2011-03-01
tech007 View Drop Down
  Quote tech007 Quote  Post ReplyReply bullet Topic: Best Thermal Compund - Grease? For CPU & GPU
    Posted: 01 Mar 2011 at 2:10pm
Arctic MX4        Arctic Silver 5
          Arctic MX2
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 01 Mar 2011 at 3:39pm
artic silver 5 is very old, outdated, outshined by the newer stuff.
I have used a lot of MX-2 easy to apply, good performance, MX-4 easy to apply better performance, longer lasting.
There are many other companies that make T.I.M.'s, some are poor, some are good, some are great. lol
  Quote tech007 Quote  Post ReplyReply bullet Posted: 01 Mar 2011 at 3:51pm
So go with MX-4? For CPU? or is there a better brand for CPU use?
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 02 Mar 2011 at 9:48am
Overall, thermal performance, ease of use, durability, MX-4 is at the top.  If a different brand gets a .5C better temp, but is harder to use, and you get a poor mount, it will perform much worse than the MX-4, plus if it does not perform well over time, then what good is it really?
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 10 Mar 2011 at 11:08am
Justin,
Using MX-4 on 1366, which application method do you prefer for that particular thermal paste? I've never used MX-4 but I'm going to be using it on a new cpu here soon, just curious.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 10 Mar 2011 at 2:41pm
a thin line, 2/3 the length of the CPU, in the center. for most CPU's I run the line perpendicular to the writing on the CPU
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 10 Mar 2011 at 6:19pm
Thank ye much good Sir
Edited by Tidgxor - 10 Mar 2011 at 6:19pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 10 Mar 2011 at 6:46pm
Also, it is a very good idea to take the cooler/water block off and check the mount. Most people put on way too much, but it depends on the type of cooler, and some other variables, but it is always a good idea to check it, if it looks bad, clean up the TIM off both surfaces, and re-do. keep trying until you get a good one. Big%20Smile
