Best way to connect monitors, DVI or RGB?
Post Date: 2008-12-08
adegiulio View Drop Down
  Quote adegiulio Quote  Post ReplyReply bullet Topic: Best way to connect monitors, DVI or RGB?
    Posted: 08 Dec 2008 at 1:45pm
If I have two video cards, what would most people suggest would be the best way to connect two monitors, using RGB cable or DVI?
TIA
skyR View Drop Down
Digital Storm Apprentice
  Quote skyR Quote  Post ReplyReply bullet Posted: 08 Dec 2008 at 1:49pm
DVI
RGB is getting old...
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 08 Dec 2008 at 1:51pm
DVI for sure
  Quote adegiulio Quote  Post ReplyReply bullet Posted: 08 Dec 2008 at 2:05pm
I kinda figured...the reason I asked is because I get better resolution choices on my current computer (which only has one card, the dual card system gets delivered today) when I connect with RGB than with DVI...
Thanks for the help
