BLUETOOTH RANGE PROBLEM! [SOLVED]
Post Date: 2016-11-15
LowRoid99 View Drop Down
  Quote LowRoid99 Quote  Post ReplyReply bullet Topic: BLUETOOTH RANGE PROBLEM! [SOLVED]
    Posted: 15 Nov 2016 at 2:24pm
Hi everyone!
I bought a PC from DS some months ago, yesterday I bought a high-end wireless bluetooth headphones and I noticed I can pair it with my PC only if I put them ON it, if I move 10cm away (yeah, 10cm for real..) from my PC, headphones disconect!
I tested them with my phone and I have a range of 8-10m more or less, so...what's the problem? I have to configure something or it's ''normal'' and I have to buy a USB bluetooth adapter??
Hope someone can help me!
Regards!
Edited by LowRoid99 - 15 Nov 2016 at 3:43pm
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 15 Nov 2016 at 2:31pm
I assume you have a motherboard with wifi/Bluetooth ?   Make sure you plugged the included antenna into the back of the motherboard.
  Quote LowRoid99 Quote  Post ReplyReply bullet Posted: 15 Nov 2016 at 3:17pm
Thanks for the answer!
Sincerelly, I don't remember wich time of Wifi/Bluetooth I have, I know my motherboard is a ASRock X99E-ITX.
There's a way I can check/I can show you which tipe of wireless connections I have?
  Quote LowRoid99 Quote  Post ReplyReply bullet Posted: 15 Nov 2016 at 3:43pm
Man, you was right! I checked in a bag with all the PC stuffs and I found it, attached it in the back part of the PC and everything seams to work!
Thank you so much!
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 15 Nov 2016 at 4:05pm
Good to hear. I just looked up your mobo and was gonna post.
