Bolt 3 Maintenance Help
Post Date: 2016-06-11
LeonRipper View Drop Down
  Quote LeonRipper Quote  Post ReplyReply bullet Topic: Bolt 3 Maintenance Help
    Posted: 11 Jun 2016 at 4:54pm
Hi!
The Bolt 3 has been my first gaming computer and i'm loving it!
I was just hoping for tips on maintaining the rig overtime with upgrades and cleaning since the case is a bit unique.
Specs:
Chassis Model: Special Deal Hot Seller - Pre-built Digital Storm Bolt 3
Exterior Finish: Black Brushed Aluminum Hairline Finish
Side Window: Edge to Edge Premium Tempered Glass
Motherboard: ASUS MAXIMUS VII IMPACT (Intel Z97 Chipset) (Mini-ITX) (SupremeFX Impact, Sonic Radar)
Power Supply: 600W SilverStone SX600-G (Gold Plus Rated) (Supports up to GTX TITAN X)
Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 8x / CD-Writer 8x)
Extreme Cooling: Custom Digital Storm (CPU Only) 240mm Liquid Cooling System
H20 Tube Color: Blue Tubing with High-Performance Fluid (UV Lighting Reactive)
Chassis Fans: Standard Black 120mm Fans
Internal Lighting: Remote Controlled Internal + Front Panel RGB LED Lighting
Airflow Control: - No Thanks
CPU Boost: Stage 2: Overclock CPU 4.5GHz to 4.8GHz (Requires High-End Motherboard Selection)
