Bolt and HEAT
Post Date: 2014-06-29
Cygnus7 View Drop Down
  Quote Cygnus7 Quote  Post ReplyReply bullet Topic: Bolt and HEAT
    Posted: 29 Jun 2014 at 10:35am
I recently purchased a Bolt and its not overclocked.  I am running the Intel Core i7 4770K processor with the ROG systemboard.
I decided to run Prime95 on it for the first time and after about 10 minutes, all 4 of my proc's were running at either 95c or 101c and it looked like it was still climging so i ended the test.
Would like some advice.  Wildstar pushes the temps to about 63c
I just wanted to see if that is to be expected or should i open a ticket with help/support.
Here are my specs.
Chassis Model: Special Deal Hot Seller - Pre-built Digital Storm Bolt
Exterior Finish: Pearl White Matte Finish with Black Vents and Black Stand
Horizontal Stand: Horizontal Stand for Bolt <b></b>
Motherboard: ASUS MAXIMUS VI IMPACT (Intel Z87 Chipset) (Mini-ITX) (SupremeFX Impact, Sonic Radar) <b></b>
System Memory: 16GB DDR3 2133MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) <b></b>
Power Supply: 500W Gold Plus Series Digital Storm Certified BOLT Edition (Enhanced Quiet Operation)
Optical Drive:  Blu-Ray Player (Blu-Ray 6x) & DVD/CD Writer <b></b>
Storage Set 1: 1x (128GB Solid State (By: Samsung) (Model: 840 Pro Series) <b></b>
Storage Set 2: - No Thanks <b></b>
Graphics Card(s): 1x NVIDIA GeForce GTX 780 Ti 3GB (Includes PhysX)
Extreme Cooling: High Performance Cooler with Four Heatpipes
Edited by Cygnus7 - 29 Jun 2014 at 3:48pm
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 29 Jun 2014 at 10:46am
Prime95 is at the top of cpu stress testing, but those temps are still too high in my book.
What cooler do you have?     Make sure the fan is working, no dust buildup in the small spaces behind the fan where the cooling fins are.
Make sure the fans are on performance in the Bios.   Sometimes they're tweaked down for lower noise.
You can also try IntelBurnTest or OCCT to stress and compare temps.   OCCT has its own monitoring or use HWMonitor for a second opinion for the others.
Edited by bprat22 - 29 Jun 2014 at 10:53am
  Quote Cygnus7 Quote  Post ReplyReply bullet Posted: 29 Jun 2014 at 3:48pm
Thank you for the suggestion.  QFan is enabled on the proc and the chassis fans.  The preset was set to standard, i changed it to turbo and it performed much better, now it took about 10 minutes using Prime95 to get the temp to 100c.
I want to try turning off qfan and see if that makes any difference, but right now my daughter is watching a movie on the apple TV so i can't reboot LOL
thanks again for your reply.  I updated my post with the specs.  I am also using HWMonitor to get my temps.
