Bolt II fully loaded (will it have heat issues?)
Post Date: 2015-01-30
LDLD View Drop Down
  Quote LDLD Quote  Post ReplyReply bullet Topic: Bolt II fully loaded (will it have heat issues?)
    Posted: 30 Jan 2015 at 8:33am
5,000-ish
Gaming rig for my HDTV
Gaming
Hi guys,
I am just concerned about the cooling. There's no cooling included for the Titan Z right? Isn't this a big deal since the card has heating issues?
Some of my DS purchasing history:
I bought a laptop from DS many years ago and it's basically a brick now. I RMA'd it 2 times and it completely failed again 2 years ago (at which point, I gave up on it).
I bought 2 desktops from DS. They went through modifications/upgrades. This desktop is still in good shape. I don't use it anymore though.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 30 Jan 2015 at 8:44am
Hi LDLD...  The Tiatn Z is triple slot wide to handle the cooling.  Most cards are double wide.   I haven't heard of any issues but haven't looked into it in quite some time.   The card should take care of itself with its fan and heatsinks.  .    The Bolt is vented so the card pulls air directly into it and the rear of the card exits the heat.
Hope this helps.  Big%20Smile
Edited by bprat22 - 30 Jan 2015 at 8:44am
Nav View Drop Down
  Quote Nav Quote  Post ReplyReply bullet Posted: 31 Jan 2015 at 11:41am
As long as it isn't in a closed space, the Bolt II won't have any cooling issues. The GPU and CPU cooling both get direct air-flow for cooling.
