Bolt ver 2 running to hot ??
Post Date: 2014-07-02
Timmyny View Drop Down
  Quote Timmyny Quote  Post ReplyReply bullet Topic: Bolt ver 2 running to hot ??
    Posted: 02 Jul 2014 at 6:41am
my config....
Motherboard: ASUS P8Z77-I Deluxe (Intel Z77 Chipset) (Mini-ITX)
System Memory: 16GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Power Supply: Optical Drive: DVD/CD 8x Multi-Drive (Writes and Reads DVDs, CDs)Storage Set 1: 1x (256GB Solid State (By: Samsung) (Model: 840 Pro
Storage Set 2: 1x (1TB Western Digital Caviar (7200 RPM) (Model: Black Edition)
Graphics Card(s): 1x NVIDIA GeForce GTX 770 2GB (Includes PhysX)
I have been noticing the system fans have been running high the last few weeks... here are my temps when that happens... do you think this is running to hot ??
thx for the reply's
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 02 Jul 2014 at 6:59am
Now is this on idle or under load?
  Quote Timmyny Quote  Post ReplyReply bullet Posted: 02 Jul 2014 at 7:17am
That was under load playing world of warcraft....
This is idle just surfing the web
PcKiller View Drop Down
  Quote PcKiller Quote  Post ReplyReply bullet Posted: 02 Jul 2014 at 7:41am
It looks go to me. I have OCed my PC and got higher temps. You sure by fine.
I-5 14600 KF
ASUS Prime Z790-P D5
SSD M.2 2TB Samsung 990 PRO
RTX 4080 16GB
Asus PB278Q 27" 2560 by 1440
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 02 Jul 2014 at 7:46am
Those temps are perfectly fine.   Anything in the mid  70's or lower is great for both the 3770k and your gtx 770.  Even low 80 is safe but 70's or lower mean cooling is doing its thing.
Enjoy. Big%20Smile
  Quote Timmyny Quote  Post ReplyReply bullet Posted: 02 Jul 2014 at 8:34am
ok great... thanks for the reply's
Meller View Drop Down
  Quote Meller Quote  Post ReplyReply bullet Posted: 02 Jul 2014 at 10:45am
Keep in mind you're talking a very small compressed case, and ambient temps play a huge factor for you. So if your room is warm, it's only going to increase.
But I mean, I play WoW pretty hard core, not to mention I stream. WoW is a CPU intensive game, more so than a GPU intensive game.
For example someone with a 4770k and a GTX 760 will get more performance over someone with a 4570k and GTX 770.. So in other words... you're fine. You're below 50, in a small tight case, where room temps play an even bigger factor for you than someone with a large full tower case.
And on that note, what server you play on? You pvp or pve? Link your armory, bro...
Custom PC
Ryzen 9 5950X
Gigabyte X570 Aorus Xtreme
128GB DDR4 3600mhz
Samsung 980 Pro 512GB m.2
Samsung 960 PRO 2TB m.2 x2
  Quote Meller Quote  Post ReplyReply bullet Posted: 02 Jul 2014 at 10:46am
How high do you go? I'm @ 4.4ghz on my main rig and hardly ever break 50... I'd have to run Prime95 for like 6 hours to get it into the high 50's low 60's.
Custom PC
Ryzen 9 5950X
128GB DDR4 3600mhz
  Quote PcKiller Quote  Post ReplyReply bullet Posted: 02 Jul 2014 at 12:00pm
At 4.0GHZ underwater, it will top out at 53C after a full 24 hours of blend Prime 95.
I-5 14600 KF
RTX 4080 16GB
Nav View Drop Down
  Quote Nav Quote  Post ReplyReply bullet Posted: 02 Jul 2014 at 6:29pm
Those are perfectly good temps.
