Bolt X CPU LED Color
Post Date: 2019-07-16
Hutch View Drop Down
  Quote Hutch Quote  Post ReplyReply bullet Topic: Bolt X CPU LED Color
    Posted: 16 Jul 2019 at 4:15pm
Does anyone know of a way to change the LED color of the Digital Storm logo on the Bolt X CPU water block? I've looked for buttons or jumpers but no such luck.
The red orange color isn't bad but conflicts with the other color schemes I'm playing around with.
Thanks!
Bolt X (aka "Stormy")
i7-8700K 32Gb DDR4 RAM
ASUS ROG STRIX Z370-I
980 Pro 1Tb SSD NVME
4TB EVO 870
GeForce GTX 1080i
HydroLux CPU/GPU
EKWG Res/Pump
  Quote Hutch Quote  Post ReplyReply bullet Posted: 22 Jul 2019 at 2:26pm
Bump. Does anyone have any ideas about this? Is it even possible to change?
HockeyBuck View Drop Down
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 22 Jul 2019 at 8:39pm
You will need to ask DS Support about that one...lol...
  Quote hoserator Quote  Post ReplyReply bullet Posted: 23 Jul 2019 at 2:27am
I am not home but your cpu block is the same I have and I wrote down somewhere what brand it is. It is not manufactured by DS but by a third party with DS labeling. Maybe someone can enlighten us as to who makes that model. With that information, you can visit their website and see if the color is adjustable. Big%20Smile
  Quote Hutch Quote  Post ReplyReply bullet Posted: 23 Jul 2019 at 8:25am
Thanks for the suggestion. I'll contact DS to see if maybe they can tell me who made the CPU block so I can run it down that way.
The GPU block is an EK model but there are not brand markings or logos on the CPU block that I can see.
  Quote hoserator Quote  Post ReplyReply bullet Posted: 23 Jul 2019 at 2:14pm
Hi
Home now and it is a Swiftech, Mine has the Swiftech logo on it instead of DS.
Hope this helps. Big%20Smile
