Bolt X water cooling manufacturer
Post Date: 2019-11-19
lomoring View Drop Down
  Quote lomoring Quote  Post ReplyReply bullet Topic: Bolt X water cooling manufacturer
    Posted: 19 Nov 2019 at 9:11pm
Hi
My Bolt X purchased on 3/2018 and need a replacement water cooling system.  What is the new manufacturer of the cooling system used?   Will this work on the older Bolt X cases?
Thanks
HockeyBuck View Drop Down
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 19 Nov 2019 at 9:27pm
In Bolt X, DS uses a cooler made by Swiftech as the HydroLux Pro Lite, and in other DS builds as HydroLux Lite.     You will need to contact DS Support to see exactly what coolers they say will fit in your 2018 Bolt.
