brothers vanquish problem
Post Date: 2016-08-07
beronsus View Drop Down
  Quote beronsus Quote  Post ReplyReply bullet Topic: brothers vanquish problem
    Posted: 07 Aug 2016 at 7:11pm
hey,
my brother bought a vanquish in january 2016, and it seems to have an issue. the pc will turn on for about 10 seconds, then will power off and it will automatically repeat this. i have removed the ram and tried to power on the pc, but the same issue occurs. there is also no display to the monitor.
anyone have a clue as to what could be the issue? a possible faulty psu?
thanks!
db188 View Drop Down
  Quote db188 Quote  Post ReplyReply bullet Posted: 07 Aug 2016 at 7:54pm
could be, but troubleshoot some.  check all of your psu connections to each component.  try reseating graphics card, memory, drives, etc.  try removing any extra peripherals besides keyboard, mouse and monitor and then try booting again.
clear CMOS (refer to your mobo manual).  verify boot order in the bios (refer to your manual on how to) is correct.  remove any overclock and reset to default bios settings.  if it's the graphics card, you can try booting without it installed and plug your monitor into the mobo directly.
try restarting into safe mode w/networking if it still won't boot properly.  try 1 stick of ram at a time in the first slot (move to other slots if problem doesn't resolve).  if you can get the pc to stay on at any point try running the Windows Memory Diagnostic tool.  make sure all your drivers are up to date.
do you have a Corsair psu and if so, do you have Corsair Link installed and running?  you can check you psu voltages with this app.  otherwise, you'll need a multimeter to do so.  do you have a spare psu?
Aventum 3
I7-6700K
Gigabyte G1 Z170X Gaming GT
Corsair Hx1000i 1000W
Gigabyte M28U 4K
  Quote beronsus Quote  Post ReplyReply bullet Posted: 07 Aug 2016 at 8:34pm
thanks for the reply.
I have made that sure all of the PSU connections are properly connected. I have reseated the video card, and ram to no avail. I have also tried on-board video but there is no display to the screen either. I'm not able to boot into safe mode as the desktop will just continuously boot and reboot within seconds. The PSU that came with the desktop is an EVGA brand so there isn't corsair link installed.
I did try and hook a different PSU to the PC, only the CPU fan was spinning though and nothing else turned on however the PC did not boot and reboot with the EVGA psu
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Aug 2016 at 9:11pm
disconnect everything connected to the psu but the motherboard, does the pc still reboot? If yes disconnect fans/cooler/hdd/ssd/dvd and things like that, and see if it still reboots. At this point we are just tyring to not have it reboot and get into bios. you can have the montior connected to the mobo(not gpu) during this.
Edited by DST4ME - 07 Aug 2016 at 9:15pm
  Quote db188 Quote  Post ReplyReply bullet Posted: 07 Aug 2016 at 10:10pm
okay. sounding more like a bad mobo to me, but try reseating the CMOS battery first.  it will clear CMOS and might get you into the bios.  have you noticed if a 2-digit q-code displays on the mobo during the period it is on?
Aventum 3
I7-6700K
Gigabyte M28U 4K
  Quote beronsus Quote  Post ReplyReply bullet Posted: 08 Aug 2016 at 7:16am
reseated the cmos, and still nothing. there is also no 2-digit q code display when the mobo is powered on
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 08 Aug 2016 at 7:27am
Remove the graphics card and try it.
Unplug both cables to your drives and try it.
Plug your pc directly into a wall outlet, bypassing any surge protector.
  Quote beronsus Quote  Post ReplyReply bullet Posted: 08 Aug 2016 at 8:18am
plugged the pc directly into the wall outlet and it magically started working again... i wonder why that is.
anyways, i'll report back if something new arises.
thanks for all your help!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 08 Aug 2016 at 8:56am
Whatever you had it plugged in has gone bad.
Next time you have any power issues always mention that you are not directly plugged in the wall.
Edited by DST4ME - 08 Aug 2016 at 8:57am
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 08 Aug 2016 at 10:26am
Bypassing a power strip has fixed quite a number of issues on the forums.   Not sure why exactly, except maybe "dirty" voltage feeding the psu.
Congrats and Enjoy. Big%20Smile
  Quote db188 Quote  Post ReplyReply bullet Posted: 08 Aug 2016 at 4:16pm
99% of the time it's the simple thingsOops
Aventum 3
I7-6700K
Gigabyte M28U 4K
