Build advice (Case / Cooling)
Post Date: 2023-04-10
MrBreeze View Drop Down
  Quote MrBreeze Quote  Post ReplyReply bullet Topic: Build advice (Case / Cooling)
    Posted: 10 Apr 2023 at 5:56am
After 13 years, it is time to move on from my first DS rig. I need some help regarding case and cooling selection. I don't do a ton of gaming, but like to have the resources when I do. The computer is primarily for day to day home office / web surfing functions. I do not require lighting.
Given the length of time I have had the last computer, I realize airflow was a contributing factor in its longevity. That being said, I'm trying to decide between the Velox case, or stepping down to the Lumos or Antec cases. Also, for cooling, I would like some advice between H20 or Noctua Air.
Current config is around $2,300:
Processor: Intel Core i7-13700KF
Motherboard: ASUS Prime Z790-P D5 (Wi-Fi)
System Memory: 32GB DDR5 5200MHz Kingston FURY Beast
Power Supply: 850W Digital Storm Performance Series
Storage Set 2: 1x SSD M.2 (1TB Digital Storm M.2 Performance Series)
Graphics Card(s): 1x GeForce RTX 3050 8GB
Thanks!
JamesAstro View Drop Down
  Quote JamesAstro Quote  Post ReplyReply bullet Posted: 10 Apr 2023 at 10:59am
I have a Velox with a Noctua DH-15S cooler, and I'm shocked at how well it cools. My case fans run at only 800 RPM most of the time, and the CPU temp rarely reaches 70C, even during intense gaming.
  Quote MrBreeze Quote  Post ReplyReply bullet Posted: 10 Apr 2023 at 2:01pm
Thanks for the reply. Definitely makes it easier to lean toward the Noctua.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 10 Apr 2023 at 2:20pm
IMHO, the 13700 would be overkill for what you do. The 13600KF is not a typical i5 with only 6 cores/12 threads. the extra this chip provides goes right into performance. It also uses less juice and runs cooler.
I almost insist you get the Samsung 980 PRO 500GB for your primary boot drive. It is 3 times faster than the DS NVMe SSd. We're talking <15 second boot times and super-charging all those things you do from Windows.
The Noctua is a great part, and very likely to last longer than an all-in-one with a pump. Other than that, get ready to have your doors blown off performance-wise. this system will also last and last.
  Quote MrBreeze Quote  Post ReplyReply bullet Posted: 10 Apr 2023 at 2:45pm
Thanks for the advice. Was definitely thinking the Noctua would outlast the pump. I also agree that the Samsung is the better option for the boot drive and you make a great point about the i5 processor.
I have no doubt about getting my doors blown off. My 13 year old DS was amazing back in the day. I'll still find some use for it... maybe unraid and a media server or something.
Oh well.. time to buy a Velox. Thanks again.
Hort View Drop Down
  Quote Hort Quote  Post ReplyReply bullet Posted: 11 Apr 2023 at 6:07am
Having just received my Velox - I recommend you consider it's dimensions - it is a significant footprint and weight over 60lbs. Just make sure you've given that a thought ;)
  Quote MrBreeze Quote  Post ReplyReply bullet Posted: 11 Apr 2023 at 8:12am
It's actually smaller than my old Digital Storm Hailstorm (Black Ops). I'm pretty sure it's lighter too. I'll compare when I get the Velox.
  Quote hoserator Quote  Post ReplyReply bullet Posted: 11 Apr 2023 at 3:48pm
The Velox is a great case and has excellent cooling, both air or liquid. It has the window on the right and mobo is upside down just so you know for where it will reside.
Smile
  Quote Cretae Quote  Post ReplyReply bullet Posted: 12 Apr 2023 at 7:52pm
You're very welcome. I know you'll enjoy your system.
