Build Advice Needed - Project DaltonPost Date: 2010-02-21 |
Citius
Newbie Joined: 21 Feb 2010 Online Status: Offline Posts: 6 |
Topic: Build Advice Needed - Project Dalton Posted: 21 Feb 2010 at 3:32pm |
Ok need to say this upfront, definitely want to go with DS. Read a lot of good things. 2nd really is no limit on the build, looking for an amazing gaming powerhouse. No that doesn't quite describe what I'm looking for. More like the Roadhouse Patrick Swayze PC of the Gaming world.
This is what I have so far, tweaks/suggestions welcomed. Going to dub this Project Dalton.
Project Dalton:
Chassis Model: Cooler Master CM Storm Sniper (Black OPS Edition) Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: AMD Phenom II X4 965 (3.4GHz) (Quad Core) (Black Edition) (8 MB Cache) AM3 Socket Motherboard: Asus M4A79T Deluxe (AMD 790FX Chipset) (Socket AM3) System Memory: 8GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 1250W Enermax Galaxy EVO (Dual/Triple/Quad SLI Compatible) (Recommended) Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 2x (150GB Western Digital VelociRaptor (10K RPM) (16MB Cache) (SATA) (Extreme Speed) Set 1 Raid Options: Configure HDD Set 1 to a Raid 0 Config - Stripe Performance (Requires Two HDDs) Hard Drive Set 2: Multimedia\Data: - No Thanks Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: Blu-Ray Player/DVD Player (Play Blu-Ray and Play DVDs) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 2x CrossFire Quad (ATI Radeon HD 5970 2GB) Add-on Card: - No Thanks Sound Card: Creative Labs X-Fi Titanium Fatal1ty Champion (Includes Front I/O) (PCI-Express Slot Based) Extreme Cooling: H20: Stage 6: Sub-Zero LCS Dual Loop: CPU & Dual SLI/CrossFire Video Cards & Chipset H20 Tube Color:Blue Tubing with High-Performance Fluid (UV Lighting Reactive) Chassis Airflow: Upgrade Chassis With LED Performance Fans (Blue) (Up to 6 Fans) Internal Lighting: Internal Chassis Lighting System (UV) (Creates Glowing Effect for H20 Tubes) Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks Boost Processor: Stage 2: Overclock the processor between 4.0GHz to 4.2GHz (Requires H20 Cooling Upgrade) Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Professional (64-Bit Edition) Edited by Citius - 21 Feb 2010 at 3:34pm |
cheebamaster
Groupie Joined: 10 Feb 2010 Online Status: Offline Posts: 134 |
Quote Reply Posted: 21 Feb 2010 at 3:41pm |
Crazy setup...you should know though that there was a recall on the 5970's and they are currently backordered...which means you will have to wait awhile before you get your system if you chose to get them
Quote Reply Posted: 21 Feb 2010 at 4:15pm |
more stuff does not mean more performance.
what is your budget? and what resolution will you be gaming at? I would never recommend 2 x 5970 right now, there is a better solution tho first and foremost you want what you need, filling up yoru systme with gpus you don't need can hinder your performance due to heat and maybe other things. keep in mind: gpu rule #1: single gpu solution is always best, for performance and least amount of problems. Edited by DST4ME - 21 Feb 2010 at 4:20pm |
Citius
Quote Reply Posted: 21 Feb 2010 at 4:21pm |
No Budget. I'm sure I could drop down to 2 5870s instead.
Resolution goal is 2560x1600, but depending on the game and level of detail, may have to switch to 1920x1200.
Quote Reply Posted: 21 Feb 2010 at 4:27pm |
2 x 5870 will give you better performance then 1 x 5970 and 3 x 5870 give you better performance then 2 x 5970, just fyi.
so you want LC right or do you want me to show you the budget build that will perform the same pretty much? |
philiporphillip
Groupie Joined: 18 Nov 2009 Online Status: Offline Posts: 335 |
Quote Reply Posted: 21 Feb 2010 at 4:30pm |
why not an intel processor?
Digital Storm
haf 922 i7-920 oc'd @ 3.6 ghz (1.28v) evga x58 le edition sli cooler master v8 6 gb ddr3 1600 mhz mushkin evga nvidia geforce gtx 295 co-op edition 1000w corsair hx |
Quote Reply Posted: 21 Feb 2010 at 4:32pm |
ok highend:
Here you go Ticket# 386914 --- Price: $5586 (To see this build click here) Price after current promotion $5136 Copy of Specifications: Chassis Model: Digital Storm HailStorm (Black OPS Edition) Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 920 2.66GHz (Quad Core) Motherboard: EVGA X58 Classified 3X SLI (Intel X58 Chipset) (Supports Triple SLI or CrossFire) System Memory: 6GB DDR3 1600MHz Corsair Dominator with DHX Extreme Edition Power Supply: 1000W Corsair (Dual/Triple/Quad SLI Compatible) Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (160GB Solid State (By: Intel) (Extreme Performance) (Model: SSDSA2MH160G2R5) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: 1x (1TB Seagate/Hitachi/Western Digital (7200 RPM) (32MB Cache) (SATA) (Extreme Speed) Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs) Optical Drive 2: DVD±R/RW/CD-R/RW (DVD Writer 22x / CD-Writer 48x) Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 2x CrossFire Dual (ATI Radeon HD 5870 1GB) Add-on Card: - No Thanks Sound Card: Creative Labs X-Fi Titanium Fatal1ty Champion (Includes Front I/O) (PCI-Express Slot Based) Extreme Cooling: H20: Stage 6: Sub-Zero LCS Dual Loop: CPU & Dual SLI/CrossFire Video Cards H20 Tube Color:Blue Tubing with High-Performance Fluid (UV Lighting Reactive) Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: Internal Chassis Lighting System (UV) (Creates Glowing Effect for H20 Tubes) Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks Boost Processor: FREE: Stage 1: Overclock the processor between 3.3GHz to 3.9GHz (Requires Air Cooling Upgrade) Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: Memory Fan Kit Only (Does not include memory overclocking service) Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Professional (64-Bit Edition) Restore Kit: Digital Storm Specialized Recovery System (DVD Image Based) Virus Protection: - No Thanks Office: - No Thanks Benchmarking: - No Thanks Install/Test Game: FREE: Please include a free copy of a hot-selling game Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Black (Large) Priority Build: - No Thanks, Ship Within 5-10 Business Days After Order Is Successfully Processed Warranty: 3 Year Platinum Care Extended Parts & Labor Warranty tell me what you think, we can cut costs if you like but for the things in the pc, all parts pretty much compliment each other. |
Citius
Quote Reply Posted: 21 Feb 2010 at 4:34pm |
"Pretty much" always makes me take a step back. It either does or it doesn't lol. If your budget build can push out over 60-70 FPS on max detail settings on some top end games at those resolutions then sure. I am certainly open to suggestions/ideas. That is the reason for this post after all. :)
Quote Reply Posted: 21 Feb 2010 at 4:37pm |
pretty much means some games like crysis can't be maxed out no matter what you get.
smooth gaming is at 50 to 60 fps, 2 x 5870 will give you that with highest settings and 8x/4x aa and 16x af in 90% of the games, but also keep in mind teh config is setup so that you can add a third gpu down the road if the need arises. Edited by DST4ME - 21 Feb 2010 at 4:38pm |
Citius
Quote Reply Posted: 21 Feb 2010 at 4:43pm |
ya looks good, after I dropped mine to 2 5870s it ended up at the same price. Tad lower.
I'll play with what you posted, may tweak a thing or two.
Quote Reply Posted: 21 Feb 2010 at 4:45pm |
honestly there is nothing tweak on that build to make it perform better, only thing left to do is go 2 x 160GB intel for much faster HDD performance and room.
everything in there is top of the line in performance. cpu change will not make a difference. ram change will not make a difference. mobo change will not make a difference. gpu change will not make a difference. fan upgrade is pointless and brings more noise. fan controller is pointless and can't control all fans and temps are not as accurate as software that can report it. nose reduction is pointless, trap noise, trap heat. gpu oc is pointless, you will see no difference. os tweak will not make a big difference and if you need some the services you can be in trouble. I do recommend 5 year warranty tho, thats what I went with. but go ahead and play with it, at the end its your pc, I'm just proving facts and info Edited by DST4ME - 21 Feb 2010 at 4:49pm |
Citius
Quote Reply Posted: 21 Feb 2010 at 4:52pm |
As in removing the burner and the storage drive, that and changing the case you picked. lol
Probably just me, but I just do not like the looks of it. But eh, could grow on me. Edited by Citius - 21 Feb 2010 at 4:57pm |
Quote Reply Posted: 21 Feb 2010 at 4:59pm |
what would you like to change teh case too? for LC on cpu/gpu you want room and the corsair has got more room then the other cases, only the lian is bigger I think.
the dvd burner? you can go ahead a remove that, if you don't plan on burning bluray either then you can change that to a reader also. what are you changing the storage drive to? |
Citius
Quote Reply Posted: 21 Feb 2010 at 5:15pm |
I'll stick with the corsair case, but ya removing the burners. Just changing to a Bluray/DVD reader.
Removing the storage drive, as I have a storage PC already. Anything I need to "store" is on my file server of sorts.
I may add on the 2nd 160gb IBM tho, for raid 0. Not sure of the performance gain, but the extra space for OS and game installations. Edited by Citius - 21 Feb 2010 at 5:18pm |
Quote Reply Posted: 21 Feb 2010 at 5:25pm |
you mean intel 160GB ssd right?
all changes sound good, raid will give you more room, and faster speeds with read and write. |
