Build advice please
Post Date: 2010-08-17
Entropius View Drop Down
  Quote Entropius Quote  Post ReplyReply bullet Topic: Build advice please
    Posted: 17 Aug 2010 at 5:40am
Hello all, I came across the DS website a couple weeks ago, and I'm very impressed with the build options, customer service reviews, and forums.
My budget for a new rig is about $2300. I plan to use the computer for games mostly, but music, movies, and some dvd encoding are also important. I also still need a monitor in the price range of $200-$300. I've been looking at monitors on newegg (not necessary buy from them) if anyone has any input.
http://www.digitalstormonline.com/comploadsaved.asp?id=433047
I did trim most of the fat and I'm pretty happy with this build. I was on the fence about a couple options. My first build didn't have a sound card, but every computer I've ever owned had one. I have Klipsch 4.1 pro media speakers that are sill hanging in there after 10 years, would replace with Logitech Z-5500 if I needed to.
I oped for the Corsair power supply over the DSO. Second would I see any big difference in temps or over clocking with the d-14 cooler ? Lastly is there any real difference between the EVGA 480 and the regular version besides the step up program and warranty ? Do you think the EVGA brand is worth the extra money ?
teaiewold View Drop Down
  Quote teaiewold Quote  Post ReplyReply bullet Posted: 17 Aug 2010 at 6:05am
that's a great build and you pretty much nailed it. to answer some questions.
1. if you feel more comfortable with the corsair psu then go for it. you probably wouldn't even notice the difference between the DS (DS tests everything before they send it out to make sure it works well) or corsair one.
2. there's really only a 1-3 degree difference between the noctua's your fine with the first one.
3. there's no difference between the evga and reg version performance wise. evga just tends to have great customer service, but so does DS so if you want to save a couple bucks you could go with the reg one.
other than that, great rig it should bring you lots of enjoyment :)
rayfinkle View Drop Down
  Quote rayfinkle Quote  Post ReplyReply bullet Posted: 17 Aug 2010 at 8:02am
We have almost the exact same build. Mine just has an 80 gig SSD and a 500 HHD + Bluray. From all that I have gathered with my research and the advice on these forums, that build is pretty much the best value you can get.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 17 Aug 2010 at 9:19am
looks good to me, sucks that they took out the $100 sound cards.. if you have sound cards in your older computers, you can take steal one and put it in your new computer.
the tech for sound cards really hasnt changed much over the past several years, im using one that i think came out in 2005 or maybe 04?
i like your choices, and no i dont think its worth the weight or cost for the noctua 14
as was said, no difference in the evga brand. youre buying the name, which does look good on the side of those cards  :)
  Quote Entropius Quote  Post ReplyReply bullet Posted: 17 Aug 2010 at 1:51pm
Thanks for the replays. My current sound card is from 04-05, but I've been having trouble with it, so went for the new one. I'd rather have DS support than creative also. Can anyone with a cooler master case tell me if the front hot swap HHD bays work well ? Do you get full rated speed ?
Edited by Entropius - 17 Aug 2010 at 1:51pm
