Build Advice
Post Date: 2011-05-12
stormyal View Drop Down
  Quote stormyal Quote  Post ReplyReply bullet Topic: Build Advice
    Posted: 12 May 2011 at 4:37pm
Here is my latest configuration.  I plan to use the PC for Flight Simulation and Starcraft II.  Do you think I will have any trouble overclocking above 4 MHz on air?  Is water cooling better?  I am apprehensive about water cooling (leakage). Is the power supply of good quality and sufficient for my system?
Thanks!
stormyal
Chassis Model: Special Deal Hot Seller - Cooler Master CM 690 II Advanced Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish
System Memory: 8GB DDR3 1600MHz Corsair Dominator DHX (High-Performance)
Hard Drive Set 1: Operating System: 1x (300GB Western Digital VelociRaptor (10K RPM) (16MB Cache)
Optical Drive 1: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 1x NVIDIA GeForce GTX 460 1GB (Includes PhysX) (Overclocked Edition)
H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: - No Thanks
Boost Processor: FREE: Overclock the processor between 3.3GHz to 3.9GHz Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Home Premium (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows 7 CD) Virus Protection: - No Thanks
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 12 May 2011 at 6:41pm
thats all wrong, what is the budget, what is the res, do you want sli ability (I don't believe fsx supports sli) and if you have a ticket number for that build please.
  Quote stormyal Quote  Post ReplyReply bullet Posted: 12 May 2011 at 9:57pm
OK.  Budget is < $2000.  Ticket # 536356.  You are correct; FSX does not support SLI, so I don't really need that capability.  However, FSX needs alot of CPU power to maintain high framerates.  I will definitely OC the Sandy Bridge as much as I can, and stay within my budget.
Thanks!
stormyal
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 13 May 2011 at 1:39am
LOL you forgot to tell me your res boss, What is the native resolution of the monitor you gonna be gaming at?
this is going by your build not knowing your res:
Here you go Ticket# 541307 --- $1960 (To see this build click here)
Motherboard: ASUS P8P67 (Intel P67 Chipset) (New B3 Revision) (Does Not Support SLI)
Hard Drive Set 1: Operating System: 1x (120GB Solid State (By: Intel) (Model: 320 Series SSDSA2CW120G3K5)
Video Card: 1x NVIDIA GeForce GTX 560 Ti 1GB (Includes PhysX Technology)
Edited by DST4ME - 13 May 2011 at 1:40am
  Quote stormyal Quote  Post ReplyReply bullet Posted: 13 May 2011 at 1:23pm
Sorry; I have a 24" widescreen monitor native resolution 1920 X 1200.
Thanks for your help!
stormyal
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 13 May 2011 at 4:18pm
For that res, change the gpu in above config to 570 gtx.
keep in mind it can't do sli.
This page was generated in 0.125 seconds.
