Build AdvicePost Date: 2013-02-01 |
Page 12> |
Author | ||
wwoods
Newbie Joined: 01 Feb 2013 Online Status: Offline Posts: 28 |
Topic: Build Advice Posted: 01 Feb 2013 at 3:05pm |
So, I am considering this build. It will be a dual purpose system. Work (I am a developer, and will have from 3-6 VM's open at any one time, hence 32GB Mem) and play, Crysis, Skyrim and the like, plus a few MMO's, EQ2, SWTOR and hopefulle TSO Online when it hits.
Looking for something to last me a few years, 3 or so, without being totally outdated by then. So....what ya all think, what would you change. Total cost of system: 3,554.00 + Shipping ============================ Chassis Model: Special Deal Hot Seller - Corsair Carbide 300R (With Window) Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 3930K 3.2GHz (Unlocked CPU for Extreme Overclocking) (Six-Core) Motherboard: ASUS Sabertooth X79 (Intel X79 Chipset) (Features USB 3.0 and SATA 6Gb/s) System Memory: 32GB DDR3 1600Mhz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 800W Corsair GS (Dual SLI Compatible) Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (180GB Solid State (By: Intel) (Model: 520 Series) Set 1 Raid Options: Configure HDD Set 1 to a Raid 1 Config - Mirror (Requires Two HDDs) Hard Drive Set 2: Multimedia\Data: 1x (1TB Western Digital Caviar (7200 RPM) (Model: Black Edition) Hard Drive Set 3: Backup\Misc.: 1x (1TB Western Digital Caviar (7200 RPM) (Model: Black Edition) Optical Drive 1: ASUS Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs) (Model: BC-12B1ST) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card(s): 1x NVIDIA GeForce GTX 680 2GB (Includes PhysX) (Overclocked EVGA) Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: H20: Stage 2: Digital Storm Vortex 240mm Radiator Liquid CPU Cooler (Extreme-Performance Edition) H20 Tube Color: - Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Airflow: Upgrade Chassis With Zalman Performance Fans (Up to 6 Fans) Internal Lighting: - No Thanks Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: Noise Suppression Package Stage 1 (Optimized Airflow & Fan Speeds Only) LaserMark: - No Thanks CPU Boost: Stage 2: Overclock CPU 4.5GHz to 4.8GHz (Requires Pro/Deluxe/Sabertooth Motherboard) Graphics Boost: - No Thanks, Please do not overclock my video card(s) Memory Boost: Memory Fan Kit Only (Does not include memory overclocking service) OS Boost: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Home Premium (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: - No Thanks Office: - No Thanks Game: - No Thanks Display: Acer 23 inch (Widescreen) (Black) (High-Performance Gaming Display) Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: Corsair Vengeance K90 (MMO Mechanical Gaming Keyboard) (Black/Metal Finish) Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: - No Thanks Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Customer Care with 3 Year Limited Warranty ========================================
ArkansasWoman777
Quote Reply Posted: 01 Feb 2013 at 3:07pm | |
I would suggest buying the monitor and keyboard elsewhere. Amazon and Walmart i know have the keyboard for 113 dollars.
wwoods
Quote Reply Posted: 01 Feb 2013 at 3:09pm | |
OK, other than that, opinions ?
ArkansasWoman777
Quote Reply Posted: 01 Feb 2013 at 3:20pm | |
If you are interested in a quite pc i would recommend the slade. 782572. I tried to match what you had configured but with a different case. Cost: 3,193. I know i'm not to much help on advice but others on here i know can give more helpful advice/opinions.
wwoods
Quote Reply Posted: 01 Feb 2013 at 3:50pm | |
Hmm took a look at that and I like, decided to modify it a bit and have this: 782582 Chassis Model: Special Deal Hot Seller - Corsair Obsidian 550D Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 3930K 3.2GHz (Unlocked CPU for Extreme Overclocking) (Six-Core) Motherboard: ASUS Sabertooth X79 (Intel X79 Chipset) (Features USB 3.0 and SATA 6Gb/s) System Memory: 32GB DDR3 1600Mhz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 800W Corsair GS (Dual SLI Compatible) Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (180GB Solid State (By: Intel) (Model: 520 Series) Set 1 Raid Options: Configure HDD Set 1 to a Raid 1 Config - Mirror (Requires Two HDDs) Hard Drive Set 2: Multimedia\Data: 1x (1TB Western Digital Caviar (7200 RPM) (Model: Black Edition) Hard Drive Set 3: Backup\Misc.: 1x (1TB Western Digital Caviar (7200 RPM) (Model: Black Edition) Optical Drive 1: ASUS Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs) (Model: BC-12B1ST) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card(s): 1x NVIDIA GeForce GTX 680 2GB (Includes PhysX) (Overclocked EVGA) Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: H20: Stage 2: Digital Storm Vortex 240mm Radiator Liquid CPU Cooler (Extreme-Performance Edition) H20 Tube Color: - Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: - No Thanks Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: Noise Suppression Package Stage 1 (Optimized Airflow & Fan Speeds Only) LaserMark: - No Thanks CPU Boost: Stage 1: Overclock CPU 4.0GHz to 4.4GHz Graphics Boost: - No Thanks, Please do not overclock my video card(s) Memory Boost: - No Thanks, Please do not overclock my memory OS Boost: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Home Premium (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: - No Thanks Office: - No Thanks Game: - No Thanks Display: Acer 23 inch (Widescreen) (Black) (High-Performance Gaming Display) Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: Corsair Vengeance K90 (MMO Mechanical Gaming Keyboard) (Black/Metal Finish) Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Black (Extra Large) Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Customer Care with 3 Year Limited Warranty A tad less OC on the proc, but a quieter system..... Comes to 3552 + shipping
Edited by wwoods - 01 Feb 2013 at 3:51pm |
ArkansasWoman777
Quote Reply Posted: 01 Feb 2013 at 3:56pm | |
That does look good. Although if you stick with stage 2 h2O i heard that it will be louder than stage 1 h2O since the Slade is suppose to be a noise reduction tower and the guidelines recommend that you use the Stage 1 Vortex 120mm
Edited by ArkansasWoman777 - 01 Feb 2013 at 3:57pm |
wwoods
Quote Reply Posted: 01 Feb 2013 at 3:58pm | |
Ya dont think that would make a big difference in how cool it stays ?
ArkansasWoman777
Quote Reply Posted: 01 Feb 2013 at 4:03pm | |
I honestly couldn't tell you. I think the people who are most familiar with the vortex cooling would have to tell you that.
Quote Reply Posted: 01 Feb 2013 at 4:16pm | |
Hi wwoods.... ArkansasWoman777 steered you to a better case over the 300r. Your build looks great, and alot quieter than your original with those noisy Zalman fans.
One thing to consider.... The 550D is quiet because of the top and side acoustic, sound deadening, panels being on. With the Vortex 240 the top panel stays off because the rad mounts up top. The quiet goes away. The option is either go with Vortex 120 that mounts against the inside back wall allowing top panel to stay on or go with the newer Corsair H100i with its better fans and Corsair Link software that allows the fans to be adjusted for speed and noise. Or, go with the the 500r or HafX case under Special Ops. The 500r has a side panel 200mm fan to feed fresh air to the video card and mobo. The HafX is the best air cooled case and quiet with large slow moving fans that push lots of air. The gtx 670 is within 5-10% of the performance of the 680 for alot less money. Just another way to get the most for your money. Change to Window 7 Pro to use over 16gb ram. Hope this helps and good luck. Edited by bprat22 - 01 Feb 2013 at 4:17pm |
Quote Reply Posted: 01 Feb 2013 at 4:22pm | |
For cooling, in general, the Vortex 120 is for stage 1 oc and the Vortex 240 or Corsair H100i for stage 2 oc.
If you go with the 500r or even better the Dreadnought HafX case, you can use the Noctua D14 air cooler. Its very reliable and quiet. Lots of ways to go. You could go to Dreadnought level 3 and make your drive selections. Add the Noctua D14 cooler and gtx 670 and that would be my pick. I can't do alot right now with configs and cut/paste. See what you think. I have to take off for now. See ya tomorrow. Edited by bprat22 - 01 Feb 2013 at 4:29pm |
wwoods
Quote Reply Posted: 01 Feb 2013 at 4:55pm | |
Thanks for all the tips folks, seteled on this: 782602
======================================== Chassis Model: Special Deal Hot Seller - Corsair Obsidian 550D Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 3930K 3.2GHz (Unlocked CPU for Extreme Overclocking) (Six-Core) Motherboard: ASUS Sabertooth X79 (Intel X79 Chipset) (Features USB 3.0 and SATA 6Gb/s) System Memory: 32GB DDR3 1600Mhz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 800W Corsair GS (Dual SLI Compatible) Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (180GB Solid State (By: Intel) (Model: 520 Series) Set 1 Raid Options: Configure HDD Set 1 to a Raid 1 Config - Mirror (Requires Two HDDs) Hard Drive Set 2: Multimedia\Data: 1x (1TB Western Digital Caviar (7200 RPM) (Model: Black Edition) Hard Drive Set 3: Backup\Misc.: 1x (1TB Western Digital Caviar (7200 RPM) (Model: Black Edition) Optical Drive 1: ASUS Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs) (Model: BC-12B1ST) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card(s): 1x NVIDIA GeForce GTX 680 2GB (Includes PhysX) (Overclocked EVGA) Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: H20: Stage 2: Digital Storm Vortex 120mm Radiator Liquid CPU Cooler (High-Performance Edition) H20 Tube Color: - Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: - No Thanks Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: Noise Suppression Package Stage 1 (Optimized Airflow & Fan Speeds Only) LaserMark: - No Thanks CPU Boost: Standard Intel Turbo Boost 2.0 Automatic Overclocking Graphics Boost: - No Thanks, Please do not overclock my video card(s) Memory Boost: - No Thanks, Please do not overclock my memory OS Boost: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Professional (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: - No Thanks Office: - No Thanks Game: - No Thanks Display: Acer 23 inch (Widescreen) (Black) (High-Performance Gaming Display) Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: Corsair Vengeance K90 (MMO Mechanical Gaming Keyboard) (Black/Metal Finish) Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Black (Extra Large) Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Customer Care with 3 Year Limited Warranty I am sticking with that case because it will sit on my home office, and clients are in there at times so......its a very professional looking case. Also I assume that vid card will push 2 monitors easy enough Edited by wwoods - 01 Feb 2013 at 4:59pm |
HockeyBuck
Quote Reply Posted: 01 Feb 2013 at 9:27pm | |
Hello wwoods. Like your build...
ArkansasWoman and bprat steered ya in the right direction, and DS will build you a rock solid rig. X79 and the 3930K are a great combination...I'm using them now. I do have one caution for you regarding your RAID SSD selection. As I have posted several times now, Intel has not yet seen fit to update the X79 chipset motherboard family to allow the TRIM software function to work with RAID. Despite promises, Intel may never do so this late in the game, and if DS didn't already warn you about this, DS sales reps should probably be speaking up about the TRIM issue when customers order RAID on the X79 boards to make sure they are aware. Without TRIM taking out the trash, once you have written to all the memory blocks once, your fast SSD RAID array would slow down. I discovered this fact about no Intel TRIM in RAID on X79 while my build was being assembled, confirmed it as accurate with DS, and dropped SSD RAID on my X79 /3930K Hailstorm build in Oct '12 as a result. Still plenty fast on a single SSD Drive 1. Alex....? Perhaps it's time to put a caution for DS customers on the RAID selection choices about that Intel TRIM issue with X79 chipset... |
wwoods
Quote Reply Posted: 01 Feb 2013 at 9:37pm | |
[QUOTE=HockeyBuck]Hello wwoods. Like your build...
ArkansasWoman and bprat steered ya in the right direction, and DS will build you a rock solid rig. X79 and the 3930K are a great combination...I'm using them now. I do have one caution for you regarding your RAID SSD selection. As I have posted several times now, Intel has not yet seen fit to update the X79 chipset motherboard family to allow the TRIM software function to work with RAID. Despite promises, Intel may never do so this late in the game, and if DS didn't already warn you about this, DS sales reps should probably be speaking up about the TRIM issue when customers order RAID on the X79 boards to make sure they are aware. Without TRIM taking out the trash, once you have written to all the memory blocks once, your fast SSD RAID array would slow down. I discovered this fact about no Intel TRIM in RAID on X79 while my build was being assembled, confirmed it as accurate with DS, and dropped SSD RAID on my X79 /3930K Hailstorm build in Oct '12 as a result. Still plenty fast on a single SSD Drive 1. Alex....? Perhaps it's time to put a caution for DS customers on the RAID selection choices about that Intel TRIM issue with X79 chipset... [/QUOTE Oh, I will be raiding the WD's, not the SSD]
Quote Reply Posted: 02 Feb 2013 at 3:20am | |
That build looks great. It'll be quiet but powerful.
You could go with stage 1 overclocking. It is an inexpensive boost in performance. Good luck. |
wwoods
Quote Reply Posted: 02 Feb 2013 at 6:06am | |
I thought about that, but this will also be a work system, running multiple VM's at once (anywhere from 3-6) and stability is a big deal. Would that be stable ?
wwoods
Quote Reply Posted: 02 Feb 2013 at 6:08am | |
I am planning on raiding the two Westerd Digitals and booting off the SSD. I would have assumed that my raid selection would have applied to the WD's ?
Quote Reply Posted: 02 Feb 2013 at 6:27am | |
Overclocking is usually very stable. On occasion and not common, after one takes delivery, they might have boot problems, but a quick call to DS to tweek the voltage is all it needs. DS does test for stability but every location is different. After that, all is good.
I've had mine oc'd to stage 1 for 18 months at 4.4 Ghz and vcore at 1.4 , using it many hours every day with zero problems. |
wwoods
Quote Reply Posted: 02 Feb 2013 at 6:29am | |
Yea, I did not mean to imply they dont test, I am sure they do a great job, call it paranoia....work system and all. I donno, I may, will think on it.
Quote Reply Posted: 02 Feb 2013 at 6:41am | |
No problems. All legitimate concerns that most of us had at one point. Paranoia can be a good thing.
The oc profile is saved in Bios as a seperate profile, so one can always load default profile and get rid of oc. Ya gotta do whatever makes you comfortable. |
wwoods
Quote Reply Posted: 02 Feb 2013 at 9:57am | |
Yea..I am still debating it. But, I am a little more comfortable knowing the OC profile is seperate and I can load the default whenever. One more thing, the vid card I chose, should be able to push dual monitors quite easilly ?
Quote Reply Posted: 02 Feb 2013 at 10:42am | |
The gtx 680 can drive two monitors with no problem. If you game across two monitors, which I don't believe you do, then with some demanding games the settings would have to be dropped a bit because of the added rendering needed.
Here's a link to see what it can do. Not sure what you need for the VMs, but should be very good. |
wwoods
Quote Reply Posted: 02 Feb 2013 at 10:48am | |
Yea, I dont game across 2 monitors.. The dual monitors are used when I work, vm's on one monitor and editing on other.... Thanks again for all the tips |
Quote Reply Posted: 02 Feb 2013 at 11:00am | |
Not sure how demanding your virtualizations are, 3D or not, but with the Sabertooth mobo you do have the ability to add another video card for sli if needed. I would want a little bigger psu for sli, but that's just an option you might or might not care about.
wwoods
Quote Reply Posted: 02 Feb 2013 at 11:05am | |
not 3d, mostly CLI on linux systems in VM's (vmware) running on win7, maby one or two with a real simple GUI, but nothing 3d. I may opt for the bigger power supply, maby 1k, that way if I ever do go SLI I am set in that respect. |
HockeyBuck
Quote Reply Posted: 02 Feb 2013 at 1:07pm | |
Your build shows your 180 GB Intel 520 SSD as boot drive 1, and you selected RAID 1 for drive set 1, so you will want to change that to no raid for set 1. TRIM is needed for RAID with SSD's...and it's not there for the X79 chipset to use.
You will be fine using RAID with normal HD's on the X79 mobo. You will have to ask DS Sales if they will RAID 1 the matching WD's you selected for your drive 2 and drive 3. Don't see why they wouldn't. I would agree about going with the 1050w PSU as you were considering, to better guard your easy upgrade path to 2 x SLI 680's. Never hurts to exceed your max power requirements, as all PSU power levels will degrade over time. I would definitely suggest you go LEVEL 1 overclock on the 3930K CPU ...A very inexpensive CPU boost that your cooler, K class processor and board are all designed for, adding to overall performance for very little cash. |
wwoods
Quote Reply Posted: 02 Feb 2013 at 1:24pm | |
OK....782937 is the build : Chassis Model: Special Deal Hot Seller - Corsair Obsidian 550D Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 3930K 3.2GHz (Unlocked CPU for Extreme Overclocking) (Six-Core) Motherboard: ASUS Sabertooth X79 (Intel X79 Chipset) (Features USB 3.0 and SATA 6Gb/s) System Memory: 32GB DDR3 1600Mhz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 1050W Corsair Pro Silver 1050HX (Dual/Triple/Quad SLI Compatible) Expansion Bay: Internal Digital Media Card Reader (Black) Hard Drive Set 1: Operating System: 1x (180GB Solid State (By: Intel) (Model: 520 Series) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: 1x (1TB Western Digital Caviar (7200 RPM) (Model: Black Edition) Hard Drive Set 3: Backup\Misc.: 1x (1TB Western Digital Caviar (7200 RPM) (Model: Black Edition) Optical Drive 1: ASUS Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs) (Model: BC-12B1ST) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 1x NVIDIA GeForce GTX 680 2GB (Includes PhysX) (Overclocked EVGA) Add-on Card: USB 3.0 4-Port PCI Express Card Sound Card: Integrated Motherboard Audio Extreme Cooling: H20: Stage 2: Digital Storm Vortex 120mm Radiator Liquid CPU Cooler (High-Performance Edition) H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: - No Thanks Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: Noise Suppression Package Stage 1 (Optimized Airflow & Fan Speeds Only) LaserMark: - No Thanks Boost Processor: Stage 1: Overclock CPU 4.0GHz to 4.4GHz Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Professional (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: - No Thanks Office: - No Thanks Game: - No Thanks Display: Acer 23 inch (Widescreen) (Black) (High-Performance Gaming Display) Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: Corsair Vengeance K90 (MMO Mechanical Gaming Keyboard) (Black/Metal Finish) Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Black (Extra Large) Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Customer Care with 3 Year Limited Warranty ..... Am I missing anything, takeing all the advice , this is what I have come up with. Almost at top end of my budget here...
Quote Reply Posted: 02 Feb 2013 at 1:42pm | |
I doesn't save much but, not sure you need the USB card. The case has 2 front usb 3 and the mobo on the rear i/o panel has another 4 usb 3 and 6 usb 2.0. Depends what you need, though.
The rest looks great. |
wwoods
Quote Reply Posted: 02 Feb 2013 at 2:16pm | |
Ahh, excellent, dident know had that many onboard, I will drop the extra USB card, plus that will drop the power consumption, even by a little bit. Thanks again everyone for the advice, this is gonna replace my 4 year old system been struggling with. Will be sure to post a review/pics when comes in, I will probably be ordering early next week. Gonna be a long 2 week wait for delivery.... |
tdtnsp
Groupie Joined: 23 Dec 2012 Online Status: Offline Posts: 105 |
Quote Reply Posted: 02 Feb 2013 at 2:58pm | |
Have you looked at the Dell Ultra series for monitor? I'd recommend U2412M instead of the Acer. Or you can always go to the 27'' version if needed be.
HockeyBuck
Quote Reply Posted: 03 Feb 2013 at 1:03am | |
Don't forget the free game download!
Just a thought to consider here before you decide this nice build. For only $300 difference you could be going with a 2 X SLI 670 2 GB setup now...? or $375 more for 2 x SLI 670 4 Gb now....? Either SLI 670 setup would absolutely smoke the single 680 and would be very very close in performance to 2 x SLI 680's. Perhaps you could delay the monitor & keyboard in order to pay for the higher SLI performance now...? Look at # 783190 using 2 x SLI GTX 670 4 GB cards... |
ArkansasWoman777
Quote Reply Posted: 03 Feb 2013 at 5:14am | |
Yea like i mentioned earlier you can get the keyboard for cheaper at Amazon or Walmart. Maybe even the Monitor to.
Edited by ArkansasWoman777 - 03 Feb 2013 at 9:29am |
wwoods
Quote Reply Posted: 03 Feb 2013 at 9:17am | |
Really, would a SLI 670 be that much better than a single 680 ? ... .. might have to look into that. And yea...must get the game also. How would SLI effect my heat in that rig ya think ? Other thing I was thinking, a 680 would be more "future proof"...ya think a SLI 670 would be more future prrof ?
Kamikaze
Newbie Joined: 31 Jan 2013 Online Status: Offline Posts: 7 |
Quote Reply Posted: 03 Feb 2013 at 9:24am | |
wwoods
Quote Reply Posted: 03 Feb 2013 at 9:38am | |
Quote Reply Posted: 03 Feb 2013 at 10:56am | |
A sli, gtx 670 is almost double the performance of a single 680. No contest.
Here's a link to compare the two cards in single setup. As far as heat, most not all of the heat is exhausted out the back ports of the card and out of the case. You still want decent airflow to the cards fans though. The 550D case will probably work if you game in air conditioning where the air pulled into the case is cool. The 550D is a great case but does trade cooling for quiet. For sli, I'd go to one of the cases i mentioned before but that's me.
Edited by bprat22 - 03 Feb 2013 at 11:02am |
Post Reply | Page 12> |
