Build Advice
Post Date: 2010-01-14
paux fas View Drop Down
  Quote paux fas Quote  Post ReplyReply bullet Topic: Build Advice
    Posted: 14 Jan 2010 at 11:34pm
Hi, this forum looks like a great place for advice so I thought I'd throw this out there. I'd like to play WoW and other RPGish games at 1900x1280 max settings and i'd be willing to spend anywhere up to about 3500.
I've had problems with overly loud fans in the past so I'd like this system to be as quiet as possible, whether that means liquid cooling or a special type of fan.
Thanks in advance for your help.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Jan 2010 at 12:44am
Listen, 90% of your sound comes from your gpu's fans, to bypass that we need to LC the gpus.
now keep in mind that the lc has rads, rads have fans, and the fans used here are a bit loud, so if you are very serious about quiet as possible then you need to ask DS to use low dba fans which will run you extra, but I'm not sure by how much.
Here you go Ticket# 373898 --- Price: $3606 (To see this build click here) Price after current promotion $3306
Chassis Model: Digital Storm HailStorm (Black OPS Edition)
Hard Drive Set 1: Operating System: 1x (1TB Western Digital (7200 RPM) (32MB Cache) (SATA) (Extreme Speed)
Extreme Cooling: H20: Stage 6: Sub-Zero LCS Dual Loop: CPU & Single Video Card
Exclusive T-Shirt: FREE: Digital Storm T-Shirt - White (Large)
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 15 Jan 2010 at 9:16am
Ask for scythe gentle typhoons 1150 RPM also ask for XSPC RX series Radiator(s), this combo will outperform any other combination out there when comparing noise to performance ratio.
  Quote paux fas Quote  Post ReplyReply bullet Posted: 15 Jan 2010 at 3:19pm
Thanks for the replies, so would you say that it's worth it getting the liquid cooling over just quieter fans? Because that cooling setup seems pretty expensive unless they're going to be a huge difference in the noise level.
I'm also a little concerned with some stuff I've been reading about LC requiring a lot more maintenance than air cooled, can anyone that has experience with both systems comment?
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 15 Jan 2010 at 4:19pm
It is not worth it to go liquid cooled for most people. keep overclocks mild, use 1000RPM case fans,used a  "sealed" type  case, and you will have the best value/performance. A low end water cooled set up will not out perform a good air.. So to get a good water cooled setup it costs a lot of cash.. and yes there is some addition maintenance.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Jan 2010 at 5:21pm
Well if you want less noise then you have to LC the gpus like I said, otherwise we can setup an air config for you and it will be a lot less.
maintenance is not a big deal, every month or so you want to check your liquid level and add liquid if, if needed and this will take 2 seconds.
once every 3 years you want to flush the system.
  Quote paux fas Quote  Post ReplyReply bullet Posted: 15 Jan 2010 at 6:17pm
Can you give me an idea of what the air setup would look like so I can compare?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Jan 2010 at 9:12pm
you got no ram fan here but you can ask them and see if they wil add it, it should be like $35, or you can just order and install it yourself, its real easy.
Air Cooled System:
Here you go Ticket# 374189 --- Price: $2407 (To see this build click here) Price after current promotion $2407
Trim Accents: - Not Available
Hard Drive Set 1: Operating System: 1x (1TB Seagate/Western Digital (7200 RPM) (32MB Cache) (SATA) (Extreme Speed)
Enhancements: - Not Available
Chassis Mods: - Not Available
Boost Memory: - Not Available
Boost OS: - Not Available
Office: - Not Available
Benchmarking: - Not Available
notice we changed the case for better airflow.
Edited by DST4ME - 15 Jan 2010 at 9:13pm
  Quote paux fas Quote  Post ReplyReply bullet Posted: 16 Jan 2010 at 6:00pm
Thanks, one more quick question, would it be worth going for the Radeon 5970 or is that just going to be overkill for what I'm going to be using it for?
Kinesis View Drop Down
  Quote Kinesis Quote  Post ReplyReply bullet Posted: 16 Jan 2010 at 6:25pm
imo,it will likely be overkill,if you're just playing wow,rpg's at 1920x1080/1200 resolution
the 5870 is a powerful card.
and as an aside the 5970's seem hard to acquire/find in stock.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Jan 2010 at 3:22am
5870 is more then you will ever need for wow at that res.
