build case advice
Post Date: 2010-08-15
Prittis View Drop Down
  Quote Prittis Quote  Post ReplyReply bullet Topic: build case advice
    Posted: 15 Aug 2010 at 1:16pm
432466
432470
only difference is the case
is the haf 922 going to keep the pc much cooler?
i mean the haf is a giant
the coolmaster is the same size as what i have now
if there won't be a big difference i prefer the smaller case
any feedback is welcome
sirsiddius View Drop Down
  Quote sirsiddius Quote  Post ReplyReply bullet Posted: 15 Aug 2010 at 2:01pm
The Haf 922 should offer cool as well as the 932 provided you in toss an extra 230mm fan for the side panel (which is standard for the 932 but not 922).
PS. the fan should cost around $15~20 or so.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 15 Aug 2010 at 4:21pm
the haf 922 is definitely better for cooling
realistically though, air cooling plateaus pretty quickly, unless you are looking for a higher than normal overclock, the differences will be pretty minimal
