Build final thoughts
Post Date: 2023-01-21
cabx88 View Drop Down
  Quote cabx88 Quote  Post ReplyReply bullet Topic: Build final thoughts
    Posted: 21 Jan 2023 at 8:09pm
$4K-$4.5K
Gaming computer that will last me 5+ years. Just looking for input if there are any glaring issues with this build. I've read in multiple posts that anything above the i5-13600KF is overkill for a gaming computer and that the SSD 980's are worth the price. Would like to upgrade to 4K monitors at some point.
Gaming and streaming shows. Have a separate computer for work.
NA
Saved Ticket #: 4605541
Processor: Intel Core i5-13600KF (5.1 GHz Turbo) (20-Thread) (14-Core) 3.5 GHz (Raptor Lake)
Motherboard: ASUS Prime Z790-P D5 (Wi-Fi) (Intel Z790 Chipset) (Up to 3x PCI-E Devices) (No SLI) (DDR5)
System Memory: 32GB DDR5 5200MHz Kingston FURY Beast
Power Supply: 1000W Digital Storm Performance Series (Semi-Modular) (80 Plus Gold)
Optical Drive: - No Thanks
Storage Set 1: 1x SSD M.2 (1TB Samsung 980 PRO) (NVM Express)
Storage Set 2: 1x SSD M.2 (1TB Samsung 980 PRO) (NVM Express)
Graphics Card(s): 1x GeForce RTX 4090 24GB (VR Ready)
Add On Card: - No Thanks
Extreme Cooling: H20: Stage 3: Digital Storm Vortex Liquid CPU Cooler (Triple Fan) (Fully Sealed + No Maintenance)
Software Control: - No Thanks
Mouse Pad: - No Thanks
Branded Gear: - No Thanks
Edited by cabx88 - 21 Jan 2023 at 8:14pm
  Quote Cretae Quote  Post ReplyReply bullet Posted: 21 Jan 2023 at 10:07pm
Well, you're on budget, and have selected the parts that will perform the way you need them to. Best wishes. Welcome to Digital Storm!
db188 View Drop Down
  Quote db188 Quote  Post ReplyReply bullet Posted: 23 Jan 2023 at 12:34pm
depending on the number of games (and other media) you like to keep on your drives at 1 time, i'd probably have suggested 1 bigger drive (to preserve your M.2 slots) that way you can add more storage over time if you don't like uninstalling/reinstalling games a lot.
i just got my new gaming rig: Ryzen 7950X; Asus ROG Strix X670E-E Gaming; TeamGroup 32GB DDR5-6000; Gigabyte RTX 4090 Gaming OC; T-Force 2TB A440 Pro (primary drive); Lian Li 011-D chassis; 1000W EVGA Gold PSU; EK AIO 360 Cooler.  it doesn't struggle at 4K playing tough games like: Cyberpunk 2077 and The Division 2 with all the bling, unlike my last pc.  i do miss the cooling might of my Aventum 3 custom open loop, but the AIO from EK seems to handle everything under a gaming load.
hope you get your rig sooner rather than later and enjoy it immensely!
Aventum 3
I7-6700K
Gigabyte G1 Z170X Gaming GT
Corsair Hx1000i 1000W
Gigabyte M28U 4K
  Quote cabx88 Quote  Post ReplyReply bullet Posted: 24 Jan 2023 at 5:42pm
Thanks guys, appreciate the feedback.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 25 Jan 2023 at 7:12am
Pleasure
  Quote hoserator Quote  Post ReplyReply bullet Posted: 25 Jan 2023 at 1:35pm
Welcome and congrats on your order.
Keep us posted! Smile
