Build Help, buying Today!
Post Date: 2010-07-04
RyanS View Drop Down
  Quote RyanS Quote  Post ReplyReply bullet Topic: Build Help, buying Today!
    Posted: 04 Jul 2010 at 4:05pm
Hello everyone,
I have been reading alot of posts about builds and such and want to know what you think about this before I buy.
Budget: Max at 2200.. this build was just under it.
Im using a 22in monitor, but looking to upgrade to a 24-26in within 6 months.
Thanks so much for helping
Chassis Airflow: Upgrade Chassis With LED Performance Fans (Red) (Up to 6 Fans)
Warranty: Life-time Expert Customer Care with 1 Year Hassle-free Hardware Service
rodsmith View Drop Down
  Quote rodsmith Quote  Post ReplyReply bullet Posted: 04 Jul 2010 at 4:54pm
I like the build. I will add this config with a slight change for the better hard drive,and you are at only 2099 for the build which will fit your budget nicely!
  Quote RyanS Quote  Post ReplyReply bullet Posted: 04 Jul 2010 at 6:42pm
thanks,
do you feel i need to upgrade the factory chassis fans to the high performance ones?
Whats the difference between the stage 1 Air and stage 2 air?
  Quote rodsmith Quote  Post ReplyReply bullet Posted: 04 Jul 2010 at 6:54pm
the fans couldn't hurt,but they will certainly add a bit more noise to your system!
the difference from the stage 1 air to stage 2 air from what I can see is the size of the fans
stage 1 120mm
stage 2 140mm
the extra fans upgrade will still be within your budget,so go ahead and get them
Wink
very nice system by the way!
Edited by rodsmith - 04 Jul 2010 at 6:57pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 04 Jul 2010 at 7:21pm
that is nice build but if you want to be able to go sli in the future then you need a better and bigger psu, stay away from upgrade fans, pointless and loud.
Here you go Ticket# 419968 --- Price: $2301 (To see this build click here) Price after current promotion $2301
Power Supply: 1250W Enermax Galaxy EVO (Dual/Triple/Quad SLI Compatible) (Recommended)
Hard Drive Set 1: Operating System: 1x (1TB Seagate/Hitachi (7200 RPM) (32MB Cache) (SATA) (Extreme Speed)
Video Card: 1x NVIDIA EVGA GeForce GTX 480 1.5GB (Includes PhysX Technology)
ablahblah View Drop Down
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 04 Jul 2010 at 9:58pm
DST has posted. HUZZAH!
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote RyanS Quote  Post ReplyReply bullet Posted: 04 Jul 2010 at 10:15pm
Thanks DST,
bought you config!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 04 Jul 2010 at 11:21pm
My pleasure and congrats
You will love it, this system can do dual sli 480 if you needed it to, and it can grow as big as you want it to also, first thing I would upgrade is a ssd, wait till intel's new line comes out Q4 of this year and then jump into one if you can.
remember ultimately this is what you want:
Don't fill up your HDD1 more then 50%, if think you will need more room for it then pick a bigger one.
so in your case, you get the new ssd, you then clone the 1TB hdd to the ssd using my clone guide:
you can follow my clone guide here
then you format the 1TB HDD and push it to HDD2 and the ssd will be HDD1, from this point, move all your personal/media/work files to HDD2 for storage and just keep os/apps/games on the ssd.
  Quote RyanS Quote  Post ReplyReply bullet Posted: 05 Jul 2010 at 7:26am
Thanks so much..Yea I really wanted a system that I can grow into.  Atleast with this system like you said, I can add the SSD, and the other video card whenever and I am all set.
Thanks again
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 06 Jul 2010 at 12:49am
My pleasure
ya this system and ones like this one, can grow as big as you wanted them to, you can even throw a 6 core cpu in there down the road.
