Build Help!
Post Date: 2010-08-08
Bense View Drop Down
  Quote Bense Quote  Post ReplyReply bullet Topic: Build Help!
    Posted: 08 Aug 2010 at 3:43pm
Before I start, I would like to say that I used to be an avid PC gamer that built his own computer after hours and hours of research.  Eight years later, I decided I'd let the professionals take care of it this time.  After building my first PC, I was never fully happy with the return value.  This time around, and after reading about DS PC's, I am sure I am in the right place, but I have a few questions about things that I am "out of the loop" on, so please, anyone that could help, I would appreciate your knowledge.
http://www.digitalstormonline.com/comploadsaved.asp?id=430069
Here is what I have come up with so far.  Basically I am looking for a high end PC to use as a workstation and as a gaming computer.  I just graduated and am hopefully on my way in a career of .NET development.  It's essential to have a PC at home that can handle my workload, as well as play games.
1. Which video cards support dual monitors?  All of them?  1 of them?  Honestly, the video card is what I am most puzzled about.  I don't know what the hot cards are nowadays, and I am willing to spend more money on it, but not at ton.
2.  Am I able to buy an additional Acer 22" LCD display with the promo bundle?  I have a Dell monitor now that I hate, so I would rather not use that.  Also, 22" is a decent size right?  24" seems like overkill to me, but maybe I'm wrong.  Any info you have on LCD's would be helpful.
3.  I really like this case because it looks semi-professional and also looks badass at the same time.  Is there a downfall to it?  I might be willing to spend more on another case if it has additional benefits, but if they are minimal, I will keep this one.
Let me know if there is anything that has to be changed because they don't work together/won't fit together or just because you think there is a better option.
My goal is to play Team Fortress 2 religiously and with a high frame rate while still being able to multi task.  I do plan to play Battlefield Bad Company 2 and other newer games, and I would like this computer to last me another 5-8 years if at all possible.
Thank you in advance for the help!
Dragoonseal View Drop Down
  Quote Dragoonseal Quote  Post ReplyReply bullet Posted: 08 Aug 2010 at 3:51pm
What is your budget?
What kind of workstation work do you intend to be doing?
Edited by Dragoonseal - 08 Aug 2010 at 3:52pm
Lilim
Intel Core i7 920 @4.2GHz
  Quote Bense Quote  Post ReplyReply bullet Posted: 08 Aug 2010 at 3:52pm
Around 2,000$
Would have helped to post that originally :)  Thanks!
Raif View Drop Down
  Quote Raif Quote  Post ReplyReply bullet Posted: 08 Aug 2010 at 5:34pm
acer does make a decent monitor for people who don't have a lot of money to spend on them. they don't back their product, so if you have a problem in their eyes it is your problem. i fought with acer to get a new monitor since i have a strip of white dots on the top and bottom of my screen, by the time they were coming around to sending me a new one (refurbished)... ooops your warranty has expired sorry. samsung makes a good product for a little more, but their cords are short so if you put your computer on the floor it may give you grief (6 ft cord).
you can save your self money by buying it somewhere other then here, not only do you pay a slightly inflated cost since they have to make a profit too, but you also pay individual shipping for each item. i would recommend buying all your accessories from a place like www.newegg.com or in-store. when buying accessories you need to know how they feel and look so don't buy a product with out seeing it or touching it first. this way you know your happy.
do you want the monitors displaying the same image or different ones?
the case you have chosen does not have good airflow, it is a very cheap case with poor quality and may restrict what parts can be put in your system. keep in mind the cooling package you chose only does the cpu not the gpu, which is why you need a case with good airflow.
the top air cooling cases in order:
Assassin
Haf 932
haf x
a computer bought here can last a lifetime as long as you upgrade it. the oc on the cpu will have a lifespan of 7 years roughly before it dies. the video card on the other hand will need to be upgraded before hand to keepo current with your gaming. i would not recommend going with a i7 860 since it runs of a p55 platform and it is as high as it goes. choosing a i7 930 would be your best bet because down the road when you need more processor power you can upgrade to the hex core.
here is a build for you that is extremely powerful, it is $4 over budget (bundle not included) but this will be relevant for years to come, with out the need to upgrade till after your warranty expires. you can upgrade this in the future with free labor for life. if you do not want to use SLI you can downgrade the mobo to the evga micro and save $30. the only difference between the two is a extra pcie slot for a gpu. the psu i chose for you does not have the ability to run two of the gpus selected. to run sli with this gpu you will need the 1200 or 1250 watt psu which would put you way over budget.
you can also consider ATI graphics with a 5870 which will be cheaper, but it has .5gb less vram and no physx. the 1gb and 2gb versions of the 5870 have only marginally different performance. for your needs the nvidia card would be a better choice
Edited by Raif - 08 Aug 2010 at 6:00pm
2.5 Ghz Core duo
Nvidia 9500 gt
3 gb 1033 Mhz ram
[email protected]
Raif View Drop Down
  Quote Raif Quote  Post ReplyReply bullet Posted: 08 Aug 2010 at 5:36pm
http://www.digitalstormonline.com/comploadsaved.asp?id=406199
ticket number: 430231
Motherboard: EVGA X58 LE Edition SLI (Intel X58 Chipset)
Hard Drive Set 1: Operating System: 1x (1TB Western Digital Caviar (7200 RPM) (32MB Cache) (Model: Black Edition WD1001FALS)
Optical Drive 2: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x)
2.5 Ghz Core duo
Nvidia 9500 gt
3 gb 1033 Mhz ram
[email protected]
  Quote Bense Quote  Post ReplyReply bullet Posted: 09 Aug 2010 at 10:23am
That does seem like a great system, but the price coupled with 2 monitors from where ever, the keyboard, mouse and speakers will probably put me well over 2,000$.  Plus there are some bells and whistles that I don't need, but would rather have.  Windows 7 Ultimate, 1 TB drive, or 2 500 GB drives, etc etc.
Is my build a bad one?  I do think I should change the case because I can see the airflow in my original is not good at all.
  Quote Bense Quote  Post ReplyReply bullet Posted: 09 Aug 2010 at 11:03am
How about a build like this: 430408
With just one monitor this time... http://www.newegg.com/Product/Product.aspx?Item=N82E16824236079
Any other suggestions?
  Quote Dragoonseal Quote  Post ReplyReply bullet Posted: 09 Aug 2010 at 11:37am
Kinda close to what I'd suggest.
You want a CPU cooler. You can't overclock much with the stock cooler, it can't take much extra heat. But get a good cooler like say the Stage 1 Noctua and they'll be able to overclock the 930 up to 3.9GHz easily enough. An extra 40% processing power for +$95 is a great buy.
I wouldn't recommend the free OS tweak. The disabled services or visual effects are barely even a blip on the radar of an overclocked 930 processor and you can easily miss out on helpful or nice looking things by disabling them. Better to just tweak the OS to your preferences on your own.
The only thing Windows 7 Ultimate offers you that Professional does not is multilingual support and access to encryption software. The only thing that Professional offers you that Home Premium does not is the ability to download and install XP Mode virtualization software. If you don't need multilingual support drop down to Professional, if you don't need XP Mode either drop down to Home Premium.
The second HDD for OS/apps is going the right direction, but for just a little more you can get a 40GB Intel SSD which has literately 100 times better small file read/write performance than any conventional HDD available.
So something more like this:
Ticket #430413, Price: $1985
Hard Drive Set 1: Operating System: 1x (40GB Solid State (By: Intel) (Model: X-25V Edition) (Extreme Performance)
Hard Drive Set 2: Multimedia\Data: 1x (500GB Western Digital (16MB Cache) (7200 RPM)
OS/apps on the SSD, games/movies/music/media on the HDD. If you want more HDD space it's just another $40 to upgrade to a 1TB Seagate/Hitachi, which is also a bit quicker than the 500GB.
Lilim
  Quote Bense Quote  Post ReplyReply bullet Posted: 09 Aug 2010 at 1:23pm
How much of a difference would the solid state HDD make for me?  This might be the closest to the build that I will actually buy, which would put me over my 2,000$ limit when I get a monitor and such, but at this point, why not.  I'd rather spend the extra to make it much better, but I can't see going any higher at all.
Do you suggest not overclocking the videocard as well?  To be honest, I'm sure both the processor and video card are fine standard.  But I do not want to manually overclock them in the future.  Any suggestions on this would be great.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 09 Aug 2010 at 1:47pm
for the ssd, think of everything you do that requires read/writing to the hard drive
saving, loading, opening programs, starting up the computer, things like this will move a lot faster. i think of an ssd as a luxury on a gaming machine, as it will have little to no impact on your actual playing, even though your game (timewise) will load faster)
processor is not really fine standard, its ok, but the gains from overclocking your processor are very significant
overclocking your video card is similar, but it starts out stronger. overclocking is not as significant. it is a lot easier to overclock, and can even be set to only overclock when you open a specific program, which i find very efficient. that way, if you need it juiced up a little to play a newer game, you can do that, but then you can avoid the noise when you arent using it.
Edited by !ender_ - 09 Aug 2010 at 1:49pm
  Quote Bense Quote  Post ReplyReply bullet Posted: 09 Aug 2010 at 3:37pm
so I should put OS and things like Visual Studio and photoshop onto the SSD?  Games and everything else on the normal Drive correct?
and if I just buy one monitor now (looking at that asus 23" from new egg), it shouldn't be a problem to add a second one in the near future correct?
I really appreciate all the help guys.
  Quote Dragoonseal Quote  Post ReplyReply bullet Posted: 09 Aug 2010 at 3:44pm
Correct. Games can be very nice to have on an SSD too, but considering that overall they really don't benefit too much (only start and load times) and that games take up a ton of space and SSD space is really expensive, it's usually better to just leave them on a conventional HDD.
Correct. Nvidia GPUs can run up to 2 monitors each. ATI monitors can run up to 3 monitors each.
This is assuming you're just using the second monitor for more desktop space though. If you wanted to actually game on two monitors suddenly you're running the game at 3840x1080, which is a lot harder so expect to need more GPU power for that.
Lilim
  Quote Bense Quote  Post ReplyReply bullet Posted: 09 Aug 2010 at 3:46pm
Yeah I just want expanded desktop space, although I have never seen what happens when you use 2 monitors with a game... Can I play a game on the left monitor and screw around on my desktop in the right monitor?
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 09 Aug 2010 at 3:51pm
yes i do this all the time and its one of the best things i ever did for my computing exp
dual monitors is a massive boost to productivity and multitasking, i cant even list the different ways i use both every day
  Quote Bense Quote  Post ReplyReply bullet Posted: 09 Aug 2010 at 4:56pm
so for peripherals, im going with these, what do you guys think?
Speakers: http://www.newegg.com/Product/Product.aspx?Item=N82E16836121014
Monitor: http://www.newegg.com/Product/Product.aspx?Item=N82E16824236079 (is 5ms bad compared to 2ms?)
Keyboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16823126034
Mouse: http://www.newegg.com/Product/Product.aspx?Item=N82E16826104019
Total is 314$ which im okay with I think.
  Quote Dragoonseal Quote  Post ReplyReply bullet Posted: 09 Aug 2010 at 5:24pm
Ooooh Logitech keyboard sale, score. The G110 is currently going for the same price, which is basically the same thing as the G15 except minus the LCD screen but twice the programmable buttons (12), in case you'd rather have more G-keys.
Mouse should be solid. I prefer Logitech mice with a few additional thumb buttons but those cost more at around $46.
I can't comment on the speakers or monitor. I'm monitor stupid, and I prefer gaming headsets over speakers. I can definitely recommend the Logitech G35 if you like headsets though. Their (virtualized) 7.1 surround is just dreamy in FPS games and ridiculously accurate, I've never been called a hacker so many times in my life, I have to explain to people I have a really good headset almost every game. Could use more bass, but I concede that I can only ask for so much for $95. No sound card needed, they are USB and use software instead of hardware.
Lilim
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 09 Aug 2010 at 5:37pm
go for it if you like the choices but i will say that if you are picky at all or like me and super rediculously picky, it may be a better idea to shop local, ive had to return several gaming products to best buy and they are 30 day money back no questions asked which came in really handy when shopping for new hardware
  Quote Bense Quote  Post ReplyReply bullet Posted: 09 Aug 2010 at 9:57pm
PC Ordered!
I opted to not get the SSD, and to not overclock the CPU/add a fan.  Right now I just didn't want to spend the money on these options, and its something I can add on in the future.  I just wanted to thank everyone for their help, and I will be posting a review as soon as it arrives.  Thanks again!
oh and...
@dragoonseal, I totally bought the G35 headset... I'm super excited to use it, as your review along with about a million others say how amazing it is.  Thanks for the suggestion!
$1,802.00
Video Card(s): 1x NVIDIA GeForce GTX 480 1.5GB (Includes PhysX Technology)
CPU Boost: - No Thanks, Please do not overclock my processor
Pre-Install Game: FREE: Hot-selling game with a NVIDIA GeForce GTS 250 or above graphics card
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 09 Aug 2010 at 10:21pm
i think its a very very bad idea to not get any overclock on that chip, you are giving up a potential 70% or more increase in clock speed, you might as well take a shotgun to your kneecap if you want to do that
you will cripple the power of the system, and even worse, my q6600 will bench better than your i7 9 series
id take a 470 and the overclock+noctua ANY day over a stock i7 9 series with stock cooling
im pretty sure its not even safe to use turbo with stock cooling, lol
again, seriously advise against this, it will slow your entire build down by a very noticible amount
Edited by !ender_ - 09 Aug 2010 at 10:22pm
Ch3ssplay3r View Drop Down
  Quote Ch3ssplay3r Quote  Post ReplyReply bullet Posted: 09 Aug 2010 at 10:38pm
Rofl!
yes. most definitely, get a noctua cooler and an overclock. the performance gains there are massive.
  Quote Bense Quote  Post ReplyReply bullet Posted: 09 Aug 2010 at 10:53pm
Haha sounds like its worth it... it should be alright if I call DS tomorrow to add it?
So noctua cooler with the free standard cpu upgrade to 3.3-3.9??
Appreciate you guys looking out for me :)
  Quote Ch3ssplay3r Quote  Post ReplyReply bullet Posted: 09 Aug 2010 at 11:28pm
Oh you already ordered it? yeah, just call them or send them a request ticket. Yep, that's what you should get.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 10 Aug 2010 at 12:00am
yea they will likely land around 3.75, seen a lot of 3.9s lately
like i said, if its about budget, id go to a 470 first, then drop some hdd space, then drop to a 922
anything to let the noctua u12p and a free OC in there
its no big deal that you already ordered, overclocking comes near the end anyway, doubt it would add any time to your build if the noctua is in stock
Edited by !ender_ - 10 Aug 2010 at 12:01am
  Quote Cretae Quote  Post ReplyReply bullet Posted: 11 Aug 2010 at 12:05am
Absolutely get the overclock. In effect, you are paying for a $280 CPU and getting an overclocked $1000 CPU equivalent. There is no simpler no-brainer on earth.
Coolermaster Storm Sniper
Intel Core i7 930 3.8GHz OC
EVGA X58 LE
6GB DDR3 1600Mhz Ram
750W Corsair
1TB HDD
1x ATI RadeonHD 5870 1GB
Noctua Dual 120mm
  Quote Ch3ssplay3r Quote  Post ReplyReply bullet Posted: 11 Aug 2010 at 12:24am
more than $1000 i would like to think. the 975 which runs at 3.33Ghz is $750. The 920, which runs at 2.8Ghz is $280. If we establish this relationship as linear. we get 3.33-2.8/750-280, which is approx .00113GHZ per dollar.
A 930 overclocked conservatively with a noctua cooler would be about 3.9, with potential to go higher. so by this model. a 1.1Ghz increase over the stock 2.8 of the 920 is worth $973.45. So, by that line of reasoning, a fictional 3.9Ghz quad core 900 series chip would cost $1253 While this probably doesn't apply to the real world in this fashion, the point here is, you should get the overclock.
I'm pretty sure we already convinced you, but i'm a math nerd.. i think like this all the time. lol
However, i would think by the pricing of the chips. 2.6GHZ=$260, 2.8Ghz=$280, 3.2Ghz=$500ish, 3.33Ghz=$750ish it would make more sense to model these exponentially, in which case the 3.9Ghz would be like $10000, however i'm too lazy to model this right now.
Edited by Ch3ssplay3r - 11 Aug 2010 at 12:53am
Raif View Drop Down
  Quote Raif Quote  Post ReplyReply bullet Posted: 11 Aug 2010 at 4:55am
yeah these days overclock is essential, it is the cheapest way to maximize your power in your cpu, think of it as putting in a supercharged v8 hemi in a in a tiny v4 sedan. when coupled with the right cooler nearly anything is possible. you can get your cpu to 4.0 with the 120mm dual noc fan easily, i have even seen higher benchmarks with the same cpu and cooler.
just hopefully they will still give it for free, even if they do charge you ($50 normally) it is still plenty worth it
ssd in the end is your call, if you play games where your switching servers it will get into playtime faster, loading and installing will be faster, boot up will be faster, no more annoying defrag needed, lower power consumption, longer lasting ( over a human life when left in read/write mode 24/7), no moving parts to break like in traditional hdds.
i see you dropped the second dvd drive in your latest build... with that said my build is $46 under budget and will beat the one you bought. since you wont be using sli you can drop down to a evga micro mobo (-$30) and increase your ssd/hdd performance by a few %. another think you can add is a ram cooler i think it is around $35 and it will lower your ram temp significantly. that of course if you want to spend the money, if not it is ok we just want to help.
Edited by Raif - 11 Aug 2010 at 4:59am
2.5 Ghz Core duo
Nvidia 9500 gt
3 gb 1033 Mhz ram
[email protected]
  Quote Bense Quote  Post ReplyReply bullet Posted: 11 Aug 2010 at 1:54pm
Well they added the Noctua dual fans and the free upgrade no problem! (thanks sarah!)
more importantly... http://www.newegg.com/Product/Product.aspx?Item=N82E16824236050
I already bought this monitor... it came today and its sick... now there is a 15$ promo to make it 135$ after rebate... how the hell do I talk myself out of this after I just decided against dual monitors...
Not to mention I have a 22" 1080p TV directly on the table next to my desk... can I handle 3?!  Oh god I wish I wasn't so weak...
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 11 Aug 2010 at 2:27pm
what made you decide against dual monitors? its a wonderful thing to use
  Quote Bense Quote  Post ReplyReply bullet Posted: 11 Aug 2010 at 2:33pm
not really deciding against them.. im trying to justify paying another 135$ or whatever
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 11 Aug 2010 at 3:03pm
do it!
going to dual monitors is one of the best things that ever happened to my comptuer expeirence
  Quote Bense Quote  Post ReplyReply bullet Posted: 11 Aug 2010 at 7:44pm
I did it!!!!
I can't wait to post some pictures of this set-up... its going to be glorious to wake up next to in the morning...
3 22" HD monitors, 2 for PC, 1 for TV/PS3/360
so effectively I can play PC games, PS3 games and 360 games at the same time... which clearly is a necessity.... right?!
:) thanks again guys.
  Quote Bense Quote  Post ReplyReply bullet Posted: 12 Aug 2010 at 4:21pm
So how do I play TF2 on the left monitor and still use my mouse on the right monitor?  Do I need to set up a certain system ?  buttons? mouse buttons to switch it over?
Basically someone needs to give me a crash course on having dual widescreens, because I don't want to be lost when they arrive.... everything you think I should know, please fill me in!
Thanks
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 12 Aug 2010 at 4:32pm
lol youre overcomplicating it, if you want to use the rightmost screen, you just move your mouse to the right and it will move freely from your left to right monitor, you can stretch a window across both monitors too
  Quote Bense Quote  Post ReplyReply bullet Posted: 12 Aug 2010 at 5:12pm
I understand that much haha... I mean when you play a game, do you play in windowed mode? Full screen... your mouse always stays in the game... correct?
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 12 Aug 2010 at 5:27pm
i never play in windowed mode.. used to when i played wow a long time ago, but none of the games i play now...
yes, thats correct
if you want to multitask to the other screen it depends on the game, some you only have to pause it, some you need to minimize, the steam overlay is a good thing to use too
Edited by !ender_ - 12 Aug 2010 at 5:28pm
