Build Help
Post Date: 2008-10-08
Heartsblood View Drop Down
  Quote Heartsblood Quote  Post ReplyReply bullet Topic: Build Help
    Posted: 08 Oct 2008 at 4:27pm
Will this build work? Any ideas? I would like to keep the price at $2000. Is this a good video card? Also do I really need DDR3? Thanks...
Power Supply: 750W Corsair HX (Dual SLI Compatible) (Silent Edition)
Processor: Intel Core 2 Duo E8600 3.33GHz (1333MHz Front Side Bus) (6MB Cache)
System Memory: 2GB DDR3 1333MHz Corsair
Card Reader: - No Thanks
Hard Drive 2: - No Thanks
Raid Option: - No Thanks
Hard Drive 3: - No Thanks
Video Card: ATI Radeon HD 4870 512MB
TV Tuner: - No Thanks
Modifications: - No Thanks
Protection: - No Thanks
LCD Display: - No Thanks
Keyboard: Microsoft Multimedia Desktop 3.0 (Multimedia Keyboard + Optical Wheel Mouse)
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 08 Oct 2008 at 4:29pm
ticket number please
  Quote Heartsblood Quote  Post ReplyReply bullet Posted: 08 Oct 2008 at 4:35pm
192778
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 08 Oct 2008 at 4:47pm
here you go Ticket# 192784 --- Price: $2076 (To see this build click here)
Video Card: NVIDIA GeForce GTX 260 896MB (Includes PhysX Technology)
now later down the road you can add a veloci raptor and make it your HDD1 and use the current 500GB as HDD2.
you can also add another 260 gtx down the road for more gpu power
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 08 Oct 2008 at 9:35pm
I was thinking that HM, but after your experience with 780i, I thought maybe one day he might want to OC his system so I wanted him to have the best chance, the prices are not that different these day for some reason.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 09 Oct 2008 at 12:02pm
I try and take into account everything I see here, your experience has been a very big deal to me here
  Quote Heartsblood Quote  Post ReplyReply bullet Posted: 09 Oct 2008 at 1:43pm
Thanks for the help. I really do appreciate it. Just trying to find the best build for around $2000.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 09 Oct 2008 at 2:37pm
You are very welcome, it was my pleasure good luck
SunfighterLC View Drop Down
  Quote SunfighterLC Quote  Post ReplyReply bullet Posted: 09 Oct 2008 at 3:01pm
Youre original build is nice, though to save money id recommend you drop the 790i and replace it with the P5E3. Not only is it slightly cheaper, but it will free you up to using a second ATI card in the future should you want. Though im not so sure 750W is enough for dual 4870s, you way want to check on that.
Since youre on a fairly solid budget id recommend you a dual core over a quad. It saves a goodly amount of cash. Some here will deny that and demand you use a quad because its better and faster, but in both cases when it comes to gaming the vast vast VAST majority of the time that isnt true.
Also since youre on a budget id say trim the case lighting, Unless you are going for a bling effect, thats just all fluff that wont improve your performance any. Might I add the case fans on the cooler master case are red..so that might look a little funky.
E8500@ 4.03Ghz
XFX 790i Ultra
1000W Corsair HX
2 280 GTX EVGA FTW
4GB OCZ Reaper 1800Mhz
250-80-300GB VR HD
Logitech Z-2300 2.1 Speakers
Asus Xonar 7.1
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 09 Oct 2008 at 5:22pm
I ofcoures disagree and advise you to go quad core, cause a dual core can't do what a quad core does, if you only game and game only you may want to go dual core but if you do more then just game, a dual core can't do what a quad core can.
If you want teh best your money can buy, then go with quad core, soon enough even quad cores are gonna be thing of the past
