Build help
Post Date: 2021-11-24
Kfd314 View Drop Down
  Quote Kfd314 Quote  Post ReplyReply bullet Topic: Build help
    Posted: 24 Nov 2021 at 9:11pm
[Trying to stay under 4500]
[Run most games at max settings]
[Mainly gaming]
[Please Type Here]
Saved Ticket #:4184792
[Specifications:
Processor: Intel Core i9-10900X (10-Core) (Boost Up to 4.5 GHz)
Motherboard: ASUS Prime X299-A II (Intel X299 Chipset) (Up to 3x PCI-E Devices) (ThunderboltEX Optional) (No SLI)
Optical Drive: - No Thanks
Storage Set 1: 1x SSD M.2 (1TB Digital Storm M.2 Performance Series)
Storage Set 2: - No Thanks
Graphics Card(s): 1x GeForce RTX 3080 10GB (VR Ready) <br><strong></strong>
Airflow Control: - No Thanks
Windows OS: Microsoft Windows 11 Home (64-Bit)
Mouse Pad: - No Thanks
Branded Gear: - No Thanks
Priority Build: - No Thanks, Ship Within 14-21 Business Days After Order Is Successfully Processed
Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement)]
  Quote Cretae Quote  Post ReplyReply bullet Posted: 25 Nov 2021 at 4:10am
Welcome to the Forum.
Saved Ticket:4184792 is not the system you posted.
The one you listed is not a gaming rig. You don't want a workstation CPU for today's games. Those packages are 2 years old or more, and will not perform well.
Here's much better idea within your budget:
https://www.digitalstorm.com/configurator.asp?id=4185090
Note the CPU is a 12700K. It is better for gaming because the additional cores in the 12900K don't help you. It's a cutting edge chip just out, and saves $230.
The 980 PRO is one of the fastest NVMe SSDs around. 500GB allows for a lean and mean "C" drive that you can copy, clone and scan with ease. The Digital Storm SSDs are all SATA drives, not NVMe. The 980 Pro is up to 9 times faster. A slightly slower NVMe drive in Secondary for a games library. Configure this how you want, but get a 980 PRO for your primary drive.
I see the DDR5 memory is backordered. If you don't think you can wait until end of December to begin building, it's certainly understandable. In that case, you can save a bit more and get a perfectly capable gaming rig that competes well with the DDR5 model here:
https://www.digitalstorm.com/configurator.asp?id=4185094
I can't say DDR5 is worth the wait, but it is a pretty good improvement over DDR4. Since you'll know only the performance you own, it is not likely you'll even know the difference in any games. The 12700K/DDR4 combo is faster than anything that has come before.
A word about GPUs. If you do not intend to game at 4K resolutions, or have a wide-screen, the 3080 is overkill. GPUs are selling across the board at more than double MSRP, so it's a real waste to buy more card than you need. For 1440p, a 3070 is right. We are probably just 8-10 months from the next gen from Nvidia, and a 4070 then will likely render the 3080 obsolete! Fingers crossed pricing adjusts itself, and you could have one for $600 if a 3070 would disappoint, but I doubt it would IMHO.
  Quote Onkel_Ken Quote  Post ReplyReply bullet Posted: 25 Nov 2021 at 7:54am
I followed Cretae's advice myself on the SSDs when I got my new system last week.
I am using a 500MB 980 PRO for my primary OS drive
500GB 980 PRO: Up to 6,900 MB per second
For my game library I am using a 1TB 970 EVO Plus
1TB 970 EVO Plus: Up to 3,500 MB per second
