Build Help
Post Date: 2009-09-30
Icefyre View Drop Down
  Quote Icefyre Quote  Post ReplyReply bullet Topic: Build Help
    Posted: 30 Sep 2009 at 10:48pm
Help With Build my Max Budget is $2,500.00 I have tweaked this as much as possible to my knowledge but any further help would be much appreciated...
Current Build ID is:
336675
venom View Drop Down
  Quote venom Quote  Post ReplyReply bullet Posted: 01 Oct 2009 at 12:34am
This is what I would recommend:
http://digitalstormonline.com/comploadsaved.asp?id=336696
$2548 - $200 (Promotion)
$2348
Chassis Model: Cooler Master HAF 922
Card Reader: - No Thanks
Hard Drive Set 1: Operating System: 1x (1TB Western Digital (7200 RPM) (32MB Cache) (SATA) (Extreme Speed)
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 275 896MB (Includes PhysX Technology)
Chassis Airflow: Upgrade Chassis With LED Performance Fans (Red) (Up to 6 Fans)
Windows OS: - No Thanks, Please test my memory, I will be responsible for software based support
LCD Display: - No Thanks
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 02 Oct 2009 at 6:12am
what resolution will you be gaming at, and what is the os you are going to use?
Edited by DST4ME - 02 Oct 2009 at 6:13am
