build process question
Post Date: 2007-10-04
ed1371 View Drop Down
  Quote ed1371 Quote  Post ReplyReply bullet Topic: build process question
    Posted: 04 Oct 2007 at 7:45pm
I was curious as to the process you guys use when a painted system is put together. Do you build the whole thing, then paint it with all the components still inside or do you paint it then assemble it?
Do you folks paint it "in house" or contract it out?
Silverstone TJ-10
INTEL 4790K
16 gigs ddr3
ssd and such
liquid cooled cpu
2080 RTX Super
skyR View Drop Down
Digital Storm Apprentice
  Quote skyR Quote  Post ReplyReply bullet Posted: 04 Oct 2007 at 8:01pm
paint case first obviously =p if not.. i would be scared and take my money elsewhere =\
  Quote ed1371 Quote  Post ReplyReply bullet Posted: 04 Oct 2007 at 8:08pm
only reason I asked was because when I spoke with them, they said that the only thing they were waiting on was the paint now... lt led me to believe that they put it together, then dissasemble it, paint it, then put it back together... which did sound like a lot of extra work.
Silverstone TJ-10
INTEL 4790K
16 gigs ddr3
ssd and such
liquid cooled cpu
2080 RTX Super
67alecto View Drop Down
  Quote 67alecto Quote  Post ReplyReply bullet Posted: 04 Oct 2007 at 8:15pm
Nah, they can put it all together and have the shell waiting for the case.
Think of it as the frame of a car, waiting for the body to be lowered on to it.
Twister Pro
750W PS/Q6600 2.4GHz/680i LT/2GB Corsair 800/9800GTX/X-Fi XtremeGamer/Stage 2 Cooling
Vanquish II
430W Corsair/i3 3.3 GHz/Asus H61M/8Gb DDR3 Corsair Vengeance/650Ti Boost 2Gb
  Quote Alex Quote  Post ReplyReply bullet Posted: 04 Oct 2007 at 10:42pm
Exactly. For the cases, we take apart the panels (rivets, etc) and they are off to paint. When they are ready, they are re-applied onto the chassis.
This allows us to actually build, test, and iron out issues in advance.
Bill the Cat View Drop Down
Forum Bitch!
  Quote Bill the Cat Quote  Post ReplyReply bullet Posted: 04 Oct 2007 at 10:42pm
I assume we're talking about a TJ9 here. Based on this picture:
Looks like, you can paint the front and sides any time. Those pieces just get in the way anyway. The top and bottem look necessary to hold the thing together. Alex, when you take off the top and bottem, is there anything left standing (besides EdH63....)?
On the otherhand, you could probably build the whole thing on the slide out motherboard tray and slip it into the painted case for final assembly and test.
Edited by Bill the Cat - 04 Oct 2007 at 10:52pm
  Quote Alex Quote  Post ReplyReply bullet Posted: 05 Oct 2007 at 9:35pm
Yes, but, don't forget, we also use torture racks to test the hardware before we even get into the wiring aspect. By the time we finish the torture racks and it's time to put the stuff in the chassis, the computer system's paint job is complete.
