Build review
Post Date: 2010-07-08
Masefield View Drop Down
  Quote Masefield Quote  Post ReplyReply bullet Topic: Build review
    Posted: 08 Jul 2010 at 4:11pm
Thoughts appreciated.  I'm trying to keep this shy of $3000.  The price right now is $2881.
Motherboard: EVGA X58 Classified 3X SLI (Intel EATX  X58 Chipset) (Supports Triple SLI or CrossFire)
System Memory: 6GB DDR3 1600MHz Digital Storm Certified Performance Series  (Highly Recommended) (Hand Tested)
Expansion Bay: External USB Digital Media Card Reader
Hard Drive Set 1: Operating System: 1x (320GB Western Digital (16MB Cache) (7200 RPM) (SATA)
Hard Drive Set 2: Multimedia\Data: 1x (1.5TB Seagate Barracuda (7200 RPM) (32MB Cache) (SATA) (Extreme Speed)
Optical Drive 1: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) (LightScribe Edition)
Video Card: 1x NVIDIA EVGA GeForce GTX 480 1.5GB (Includes PhysX Technology)
Sound Card: Asus Xonar D2 (HOT SELLER)
  Quote Cretae Quote  Post ReplyReply bullet Posted: 08 Jul 2010 at 5:18pm
The Classified is a great board, but may be overkill for your use. The EVGA LE is a very solid choice for average users/gamers.
The 1250W Enermax is preferable for better reliability. You would only need that much power to drive two nVidia boards in SLI. If you plan on staying with one gpu, the 750W Corsair is all you need.
With your budget, and especially with the possible savings from the above, you want an Intel SSD instead of the 320g HDD. Intel only is recommended, their overall performance is superior. Use only for OS, apps, and maybe a few games if they fit. Games don't ordinarily benefit that well from an SSD's performance, so you can get a small one just for OS and a few apps. Speed will blow you away.
Lose the "performance fans" they are loud, and the HAF X case is already one of the best air coolers on the planet. Total waste of $.
The DS oc on video cards is very conservative, and will not even be noticeable. Don't make your card run hotter.
Hope it helps.
Coolermaster Storm Sniper
Intel Core i7 930 3.8GHz OC
EVGA X58 LE
6GB DDR3 1600Mhz Ram
750W Corsair
1TB HDD
1x ATI RadeonHD 5870 1GB
Noctua Dual 120mm
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 08 Jul 2010 at 5:28pm
yea, agree with most of what cretae said, definitely drop the power supply first, you didnt mention sli, and i wont do my normal tirade against it, but going to 750 tx will be good for your budget and have some good headroom for overclocking or a future better card
as he said, the ssd, 40 or 80 gb intel is enough for your OS and main apps, should be enough in the budget for that after you drop the psu
im increasingly confused about people saying to remove DSO's gpu overclock. i mean not that its hard to use MSI afterburner on the fermis anyway, but its free, what difference does it make if you choose it?
i wont be overclocking my 470 for a while because i dont see a reason to currently. but that doesnt mean no one would.
another good way to save money is get the haf 932, unless its about looks to you the difference between these 2 cases is pretty negligible
  Quote Masefield Quote  Post ReplyReply bullet Posted: 08 Jul 2010 at 6:20pm
Great feedback - very helpful.  Thanks so much!
