Building a Gaming System
Post Date: 2007-10-27
Jesse View Drop Down
Guest
Guest
  Quote Jesse Quote  Post ReplyReply bullet Topic: Building a Gaming System
    Posted: 27 Oct 2007 at 8:56pm
Hi, I have done some research on various components, and put together several different custom builds on various websites.  I found digital storm to be the most appealing site from which to purchase a custom pc.
I was wondering if anyone had any advice for the following configuration.  My budget is around $1400-$1600. Also, I would prefer an Intel oriented build.  THANKS!
SPECIFICATIONS
Case: Digital Storm Twister PRO (Black Anodized Aluminum Finish)
Power Supply: 500W Thermaltake (Silent PurePower Edition)
Processor: Intel Core 2 Duo E6550 2.33GHz (1333MHz Front Side Bus) (4MB Cache)
Motherboard: nVidia 650i Core 2 Quad (By: eVGA) (nForce 650i Ultra)
Memory: 2GB DDR2 Corsair at 667MHz (Dual Channel)
Floppy / Media: Digital Media Card Reader (Black)
Hard Drive 1: 250GB (Western Digital / Seagate) (16MB Cache) (7200 RPM) (SATA)
Hard Drive 2: - No Thanks
Raid Option: - No Thanks
Modem: - No Thanks
Video Card: nVidia GeForce 8800GTS 320MB (By: eVGA / Asus) (PCI-Express)
TV Tuner: - No Thanks
Sound Card: Motherboard Multi-Channel High Definition Audio (7.1 Channel)
Physics Card: - No Thanks
Cooling: Air Cooled Stage 2 (Silent Artic Cooling Heat-sink (Copper Heatpipes)
Round Cables: - No Thanks
Protection: - No Thanks
LCD Display: Acer 19 inch (Widescreen) (Black Edition) (High-Value Display)
Price: $1572
67alecto View Drop Down
  Quote 67alecto Quote  Post ReplyReply bullet Posted: 27 Oct 2007 at 10:17pm
You don't really need two optical drives, and with the components you selected, I'd go with the Twister Lite case.  It looks very sharp, and if you want the lighting, it is a much better case as the Twister Pro's huge clear panel washes it out.
Personally, I would drop the monitor - Circuit City frequently has sales where you can get an excellent 19" monitor for $200 or less.
Instead, I'd go with faster memory, a faster chip, and then go to Stage 3 cooling so DSO will have even more overclocking ability.
I'll let others speak to the video card selection - I have done almost no research except on the 8800 GTX/Ultra cards.
Case: Digital Storm Twister LITE (Black Aluminum Edition)
Processor: Intel Core 2 Duo (TwisterBoost Enhanced) E6750 2.80GHz (1400MHz Front Side Bus)
Memory: 2GB DDR2 Corsair at 800MHz XMS2 (Dual Channel) (Extreme-Performance)
Modem: - No Thanks
Cooling: Air Cooled Stage 3 (Silent Artic Cooling (TwisterBoost Overclocked)
LCD Display: - No Thanks
$1473
Edited by 67alecto - 27 Oct 2007 at 10:18pm
Twister Pro
750W PS/Q6600 2.4GHz/680i LT/2GB Corsair 800/9800GTX/X-Fi XtremeGamer/Stage 2 Cooling
Vanquish II
430W Corsair/i3 3.3 GHz/Asus H61M/8Gb DDR3 Corsair Vengeance/650Ti Boost 2Gb
Guest
Guest
  Quote Jesse Quote  Post ReplyReply bullet Posted: 28 Oct 2007 at 6:11am
Thank you very much 67alecto! Great advice!!
I've made a couple other changes:
Case: Digital Storm Twister VALUE (Silver Edition)
Optical Drive 1: - No Thanks
Modem: - No Thanks
Case Lighting: - No Thanks
$1378
I was wondering if this configuration would need a better power supply??
skyR View Drop Down
Digital Storm Apprentice
  Quote skyR Quote  Post ReplyReply bullet Posted: 28 Oct 2007 at 12:02pm
500W is fine.
  Quote 67alecto Quote  Post ReplyReply bullet Posted: 28 Oct 2007 at 12:54pm
That's a good looking system.  The 8800GT cards are due out early next week - may want to check the price on those before you place your order.
Twister Pro
Vanquish II
Guest
Guest
  Quote Jesse Quote  Post ReplyReply bullet Posted: 30 Oct 2007 at 10:07pm
This is the configuration im leaning towards at the moment.  Going to buy in about a week now.
I havn't seen any good comparison information on the 8800GT 512mb vs. the 8800GTS 320mb but It looks the 8800GT 512 would be the better buy.
Case: Digital Storm Twister VALUE (Black Edition)
Memory: 2GB DDR2 Corsair at 1066MHz Dominator (Dual Channel) (Extreme-Performance)
Modem: - No Thanks
Video Card: nVidia GeForce 8800GT 512MB (By: eVGA) (PCI-Express)
$1500
..and ill probably save up to get a 24" samsung next month.
Kelly View Drop Down
  Quote Kelly Quote  Post ReplyReply bullet Posted: 30 Oct 2007 at 10:17pm
then you mustn't be looking too hard because the 8800GTS 320 is now discontinued.  The 8800GT out performs the 640 version.
Do a search on the forums.  You'll see specs.
Virshia View Drop Down
  Quote Virshia Quote  Post ReplyReply bullet Posted: 30 Oct 2007 at 10:27pm
Wait the 8800 GTS 320 mb has been discontinued? I have that card in my computer... will they still support it and have updated drivers for this card in the future?
skyR View Drop Down
  Quote skyR Quote  Post ReplyReply bullet Posted: 30 Oct 2007 at 10:36pm
Only the 8800 GTS 320MB card has been discontinued.
The 8800 GTS 640MB is getting a refresh sometime in the future.
There will still be driver support for the 8800 GTS. (320 and 640 share the same drivers...)
Guest
Guest
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 30 Oct 2007 at 11:55pm
so am I reading correctly that the 8800GT 512mb is better than the 8800GTS 640 in all respects, and $100 cheaper?
what do you mean by the "640 is getting a refresh in the future"
in my current rig that I'm about to buy i have
Power Supply: 600W Thermaltake (SLI Compatible) (Silent PurePower Edition)
Processor: Intel Core 2 Quad Q6600 2.4GHz (1066MHz FSB) (8MB Cache)
Motherboard: nVidia 680i Core 2 Quad (By: Evga) (nForce 680i SLI) (A1 Revision)
Hard Drive 1: 320GB (Western Digital / Seagate) (16MB Cache) (7200 RPM) (SATA)
Optical Drive 2: DVD-ROM/CD-ROM (DVD Reader 16x / CD Reader 40x)
Video Card: nVidia GeForce 8800GTS 640MB (By: eVGA / Asus) (PCI-Express)
Windows OS: Microsoft Windows Vista Home Premium
would the new 512 be better? (the cost doesnt bother me, i'm after performance)
skyR View Drop Down
  Quote skyR Quote  Post ReplyReply bullet Posted: 31 Oct 2007 at 12:08am
Yes the 8800GT outperforms the 8800 GTS and can give the GTX a run for its money...
Rumor has it that Nvidia will release a new 8800 GTS based on the 65nm G92. 128 stream processors (same as GTX), 512mb memory (instead of 640mb), 256-bit (instead of 320-bit).
Whoever is in charge of Nvidia's marketing team should get a medal for delivering such an outstanding card but also should be slapped for making us all confused...
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 31 Oct 2007 at 12:08am
ok i read around and I found out that the 640mb "refresh" is a new driver set for the same card as long as its evga?
any clue yet if the 640 v.2 will overshoot the 512, making the 8800GTS 640 the smarter option for the long run?
i hate computersCry
*edit* damn youre quick hahaha you answered some of my questions too fast
Edited by !ender_ - 31 Oct 2007 at 12:10am
skyR View Drop Down
  Quote skyR Quote  Post ReplyReply bullet Posted: 31 Oct 2007 at 12:14am
The GTS v2 or revision or 65nm or whatever you want to call it is going to be a new card. It is not drivers you download.
So don't get the wrong idea and purchase the current 8800 GTS 640MB thinking that downloading drivers will make it perform better than the 8800 GT.
If Nvidia does release a new 8800 GTS, it will most likely trail just a little behind the Ultra...
Edited by skyR - 31 Oct 2007 at 12:14am
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 31 Oct 2007 at 12:18am
so end of the day, unless you feel like waiting to see if the new 640, when it gets released, is better the 512 is by far the best way to go? does DSO OC video cards?
seems to think there will be a quickfix for the v2 without getting a whole new card
Edited by !ender_ - 31 Oct 2007 at 12:20am
skyR View Drop Down
  Quote skyR Quote  Post ReplyReply bullet Posted: 31 Oct 2007 at 12:25am
Yep, DSO overclocks video cards on request.
Don't spend your entire life waiting or else you going to be waiting forever (like meLOL)...
Theres rumor that annoucement/release of the new 8800 GTS will be on Nov 12th (don't count on it since it doesn't make much sense considering how the 8800 GT is in such high demand)
Theres also the ATI 3800s coming out on Nov 15th.
The 8800GT is a great investment.. im going to be purchasing one in November if ATI can't offer something good =)
Yes, EVGA offers a stepup program where you trade in old cards for new cards and you pay the price difference.
You could always get the 8800GT for now and if you aren't happy with the performance. You can trade it in for another card in the future.
Edited by skyR - 31 Oct 2007 at 12:27am
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 31 Oct 2007 at 12:41am
thanks skyR, you rock
looks like im going with the 512!
so close to deciding what to buy!
This page was generated in 7.910156E-02 seconds.
