Building advice
Post Date: 2018-05-22
Richy34Mac View Drop Down
  Quote Richy34Mac Quote  Post ReplyReply bullet Topic: Building advice
    Posted: 22 May 2018 at 7:13am
Hello, I just built this pc and I was wondering how good would this build do with Streaming, editing, and also gaming with PC and also playing on console.
Model-Digital Storm Lumosi
Exterior Finish- No
Trim finish- No
Processor- Intel Core i7-8700K (6-Core) 3.70GHz
Motherboard- ASUS ROG STRIX Z370-E GAMING (Wi-Fi) (Intel Z370 Chipset) (Up to 3x PCI-E Devices)
System memory-32GB DDR4 3000MHz Digital Storm Performance Series
More Info
Power supply- 750W Corsair RM750x (Fully Modular)
Expansion bay- No
Optical Drive- No
Storage set 1-1x SSD M.2 (500GB Digital Storm M.2 Performance Series
Storage set 2-1x Storage (2TB Seagate / Toshiba)
Storage set 3 - None
Internet- High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections)
Graphics card- 1x GeForce GTX 1080 Ti 11GB (Performance Edition) (VR Ready)
More Info
Sound card- Integrated Motherboard Audio
Extreme cooling- AIR: Stage 1: High-Performance Copper Heat Pipe Cooler
Chassis fan- Standard Factory Chassis Fans
FYI, any part I didn’t add was because i chose not to add on. Thank you again for trying to help me out.
Richy MacMullen
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 22 May 2018 at 7:44am
That build looks super to me.  Awesome
I would've picked a little different drives, but that's just me.  What you have is plenty fast.
The 1080Ti will game all the way to 4K monitor.
Big%20Smile
  Quote Cretae Quote  Post ReplyReply bullet Posted: 22 May 2018 at 9:06am
I just found out that primary drive you picked is SATA and thus limited to the much slower interface.
We like to recommend the Samsung 970 PRO for its 5 year warranty, speed and reliability. If that's not in your budget, I highly recommend the 970 EVO instead of the DS SATA part. You get true NVM Express speed and a 3 year warranty from Samsung for only $37 more.
You could consider the MSI Pro Carbon motherboard. It, too has wi-fi built in, saves a little dough, and you get much better customer responsiveness from MSI than Asus should you ever need it.
Think hard if you really want/need 32 GB of RAM. At today's prices it's pretty expensive. If you aren't doing mostly editing as opposed to your other uses, you'll never even know it's there for you.
Just some thoughts....
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 22 May 2018 at 9:51am
  Oops I misread and thought you already ordered it.  If not then go with Cretae's suggestions if you can.
Edited by bprat22 - 22 May 2018 at 9:51am
  Quote Richy34Mac Quote  Post ReplyReply bullet Posted: 22 May 2018 at 9:56am
Thank you I did go with creates input. Thanks again guys
Richy MacMullen
  Quote Richy34Mac Quote  Post ReplyReply bullet Posted: 22 May 2018 at 10:24am
One more Quick question, sorry for if this sound silly but does RAM affect how a stream runs.
Richy MacMullen
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 22 May 2018 at 11:23am
Ram does effect how smooth your gaming and streaming together will perform.    If you stream your gaming at higher resolutions like 4K, you might consider keeping the 32gb ram.
