Building Help
Post Date: 2011-02-28
Billybobjoe03 View Drop Down
  Quote Billybobjoe03 Quote  Post ReplyReply bullet Topic: Building Help
    Posted: 28 Feb 2011 at 11:35pm
Hey,
I bought a computer from DS quite a few ago and while it has done wonderfully I am feeling the need to upgrade. I am honestly a complete neophyte when it comes to the inner workings of a computer and I would like some advice on what seems to be appropriate for my needs.
My Budget is ~$2500
My expectations is that I will be able to run current and upcoming games fairly close, if not flawlessly.  I generally am playing MMO's but would like to have a system that could handle something more intense should the need arise. I don't plan on having more then one monitor and I will be running it 1920 X 1080.
The primary usage of the computer will be for running games well.  Besides that it will serve for basic needs, internet ect.
I have no special needs that I can think of.
Thank you
-Billy
*Edited for clarification
Edited by Billybobjoe03 - 28 Feb 2011 at 11:38pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 01 Mar 2011 at 12:36am
this is more then you need for mmo, but its a system that can do sli, should the need for more gpu power arise:
Here you go Ticket# 491653 --- $2553 (To see this build click here)
Motherboard: ASUS P8P67 Deluxe (Intel P67 Chipset) (Features USB 3.0 and SATA 6Gb/s)
Hard Drive Set 1: Operating System: 1x (160GB Solid State (By: Intel) (Model: X25-M MLC Edition) (Extreme Performance)
Boost Processor: FREE: Overclock the processor between 3.6GHz to 3.9GHz
if you don't need sli capability then we can change psu and mobo and save some money.
haf 200mm non led fan
Edited by DST4ME - 01 Mar 2011 at 12:42am
  Quote Billybobjoe03 Quote  Post ReplyReply bullet Posted: 01 Mar 2011 at 10:17am
Thank you very much for the help.
I just want to be sure I understand what sli is. This would basically give me the capability of adding another video card should the time come that just the one isn't cutting it correct?
coolmasta View Drop Down
  Quote coolmasta Quote  Post ReplyReply bullet Posted: 01 Mar 2011 at 10:56am
That is correct. To be honest a single 570 should be good for MMO's for quite a while.
I7 2600k @ 4.5 Ghz, Noctua D14
8 Gigs Corsair 1600
HAF 922
Evga Gtx 580
  Quote Billybobjoe03 Quote  Post ReplyReply bullet Posted: 01 Mar 2011 at 11:15am
Awesome. Thank y'all for answering my questions. Definitely feeling more informed and capable of making a better purchasing decision.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 02 Mar 2011 at 1:03am
If its just for mmo you don't need sli as they won't take advantage of it.
Invader Mig View Drop Down
  Quote Invader Mig Quote  Post ReplyReply bullet Posted: 02 Mar 2011 at 5:59am
That's not necessarily true. Rift most certainly does support sli and crossfire and will give big gains. I'm fairly certain most of the long list of new MMO's coming out this year will also support multi gpu configs. Just something for the OP to think about.
Edited by Invader Mig - 02 Mar 2011 at 6:13am
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 02 Mar 2011 at 9:59am
all MMO's support multi GPU's, it is hardware not software anyways, old ass games don't need multi GPU's, so easy to run, but yes, new ones. lol
RIFT uses 3 GPU's very well, great scaling 90%+ most all the time, when you crank up the settings, it is very taxing on a system, now 4 GPU's seems to fail, but my wife has done all the driver/GPU settings, so maybe I could get better scaling out of it, but in the past I know a lot of games did not scale well with 4 GPU's.
  Quote Billybobjoe03 Quote  Post ReplyReply bullet Posted: 02 Mar 2011 at 10:35am
hmmm, glad Rift was mentioned as it is one of the games I am currently playing and at the moment probably the most taxing (system wise) for me to run.
Thanks for the continued input.
