Building My First PC need some help
Post Date: 2014-09-03
MagicAmmo View Drop Down
  Quote MagicAmmo Quote  Post ReplyReply bullet Topic: Building My First PC need some help
    Posted: 03 Sep 2014 at 7:32am
whats going on people I have a project in mind that im going to be doing this moth and I need some help this is going to be the first computer I've ever built its going to be AMD based because its cheaper than nvidia. heres the parts list I chose
http://pcpartpicker.com/p/FHVtLk
now right now im not sure if i want to go with the amd fx 8350 or the fx 9590 I heard that you have to water cool the 9590 but im not planing to over clock so would that cooler I chose the Cooler Master Hyper 212 work for ether processor?
now in a few months I plan on cross firing the r9 290 and I dont know witch case I should get because I want a decent amount of room in it for airflow so its not too hot so whats a good case?
Behemoth
Intel Core i7 4810MQ
8GB DDR3 1600MHz
1TB 5400RPM HDD
2x SLI (NVIDIA GeForce GTX 880M 8GB with NVIDIA Battery Boost + NVIDIA Optimus)
Microsoft Windows 8.1
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 03 Sep 2014 at 7:46am
Hello MagicAmmo, from what i know the best case for airflow is the Corsair Air 450 at the moment which you can get to through the Apollo configuration by changing the Chassis Model or here is the link to the build that i made for you based on the parts list https://www.digitalstormonline.com/configurator.asp?id=1043282
Edited by ArkansasWoman777 - 03 Sep 2014 at 7:47am
Ariktu View Drop Down
  Quote Ariktu Quote  Post ReplyReply bullet Posted: 03 Sep 2014 at 11:47am
I would go for the i5 4670 instead and pay the few dollars more for better performance.
  Quote MagicAmmo Quote  Post ReplyReply bullet Posted: 03 Sep 2014 at 3:46pm
So that case can fit 3 gpu's?
Behemoth
8GB DDR3 1600MHz
1TB 5400RPM HDD
  Quote MagicAmmo Quote  Post ReplyReply bullet Posted: 03 Sep 2014 at 3:48pm
I would but I'm going for an amd build but as far as the cpu cooler goes is it a good one or not lol i dont know too much about cooling and im trying to go for a red and black look imma call it the red saber lol
Behemoth
8GB DDR3 1600MHz
1TB 5400RPM HDD
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 03 Sep 2014 at 3:51pm
I believe it can judging from the builds that people have posted over in overclock.net i have seen a few builds with 3 graphics cards in it.
http://www.overclock.net/t/1404897/official-corsair-carbide-air-540-owners-club-gallery/0_40
  Quote MagicAmmo Quote  Post ReplyReply bullet Posted: 03 Sep 2014 at 4:03pm
Thanks for the info also do you know of a good case that happens to be black and red that can hold 3 gpu and has sufficient cooling? lol
Behemoth
8GB DDR3 1600MHz
1TB 5400RPM HDD
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 03 Sep 2014 at 5:39pm
Well this case is black and red: http://www.nzxt.com/product/detail/143-h440-performance-mid-tower.html but as far as it holding 3 gpus i honestly couldn't tell ya.
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 03 Sep 2014 at 5:42pm
Course you could get a Phantom 820 in black and have the lighting set to red, it can hold 3 gpus from what i have seen on the pcpartpicker customer pictures. If you choose either cases i listed you can have DS custom order the case for a small fee i believe.
http://www.nzxt.com/product/detail/96-phantom-820-full-tower-caes.html
Edited by ArkansasWoman777 - 03 Sep 2014 at 5:43pm
