Burning smell -- fan help
Post Date: 2021-06-19
jcmcn5 View Drop Down
  Quote jcmcn5 Quote  Post ReplyReply bullet Topic: Burning smell -- fan help
    Posted: 19 Jun 2021 at 6:52pm
My rig:
Digital Storm Custom Rig
Windows 10 64-bit
Intel Core i7-2600K CPU @ 3.40GHz, 3401 Mhz,
BIOS American Megatrends 2001, 9/20/2010 19:13:52 Ver:08.00.10
Kaspersky Internet Security
Recently bought a WD My Book external HD, 6TB, model #WDBBGB0060HBK-NESN
I just started smelling something burning. Have cleaned the filters but it looks like one of the three fans at the bottom is not working (maybe the source of the smell?) but I can't seem to get to it to pull it out a replace. Is there a guide to how to get to this fan, pull it out and replace it?
  Quote hoserator Quote  Post ReplyReply bullet Posted: 20 Jun 2021 at 2:47am
Sorry about the issues. Does the pc start?
Which model DS do you have? there have been many changes through the years.
R&R a fan is pretty straight forward. Did you check the fan wires to make sure they are well connected? Haven't heard of a fan burning but ....
  Quote jcmcn5 Quote  Post ReplyReply bullet Posted: 20 Jun 2021 at 4:34pm
It's an old, custom made system from back in 2012. It's odd. I did notice that the wire connected to the front fan was disconnected, so all three fans do work. I narrowed the smell down to the fans coming from the CPU cooler, but the cooler seems to work fine, and the smell came immediately after turning the system on. No way was there enough time for anything to start overheating and burning. The cooler is old, admittedly. The original Corsair A50 unit, but after cleaning every filter and taking compressed air to everything, the smell seems to have gone away. Maybe I just let too much dust build up inside the rig.
  Quote hoserator Quote  Post ReplyReply bullet Posted: 21 Jun 2021 at 7:24am
Glad you got the fan working.
Keep your eye out on the system temps (HWMonitor) and keep the fins clean.
Smile
  Quote jcmcn5 Quote  Post ReplyReply bullet Posted: 21 Jun 2021 at 7:40am
Smile
Curious -- what should the temps be in a normal running system?
  Quote hoserator Quote  Post ReplyReply bullet Posted: 21 Jun 2021 at 4:06pm
From what I have read it will throttle at 95C. From the Intel forum it tells 30C idle and 50-60C at max load. That sounds about right.
What are you getting?
