Business solution for AutoCAD/Solidworks
Post Date: 2011-05-23
ngolden View Drop Down
  Quote ngolden Quote  Post ReplyReply bullet Topic: Business solution for AutoCAD/Solidworks
    Posted: 23 May 2011 at 11:44am
1. Around $1000-$1200, including a copy of Windows (cheaper is better)
2. I expect to use this computer for work and work only. I won't be doing any personal computing on it whatsoever and do not need excessive storage space.
3. I'll be using Solidworks doing 3D modeling and rendering (lots of rendering), and sending emails.
4. Has anyone ever ordered a computer from here with Quadro or FirePro cards? Would I be better off with a cross-fire solution with two cheaper cards or one single card solution? I probably won't be upgrading or tinkering with this system too much however I could see myself at some point upgrading the GPU(s).
Thank you for any and all help Love
  Quote ngolden Quote  Post ReplyReply bullet Posted: 23 May 2011 at 11:47am
I completed a build, ticket number 547576.
  Quote ngolden Quote  Post ReplyReply bullet Posted: 23 May 2011 at 11:50am
Sorry for the sequential replies,
Chassis Model: Special Deal Hot Seller - Cooler Master Elite 430 Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish
Processor: AMD Phenom II X4 810 (2.6GHz) (Quad Core) (2 MB Cache) AM3 Socket
Motherboard: ASUS M4A88T-M LE (AMD 880G Chipsets) (Socket AM3) System Memory: 8GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 500W Digital Storm Certified Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (500GB Western Digital Caviar (7200 RPM) (32MB Cache) (Model: Blue Edition) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: - No Thanks Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 2x SLI Dual (NVIDIA GeForce GTS 450 1GB (Includes PhysX Technology) Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: Standard Factory Heat-sink and Fan (Not Recommended for CPU Overclocking) H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: - No Thanks
Boost Processor: - No Thanks, Please do not overclock my processor Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: FREE: Yes, Disable and tweak all of the non-crucial services on the operating system Windows OS: Microsoft Windows 7 Home Premium (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows 7 CD) Virus Protection: - No Thanks
  Quote ngolden Quote  Post ReplyReply bullet Posted: 23 May 2011 at 11:55am
I should have mentioned that I'm going to want to run dual monitors from this PC and am not sure how that works when running a 2 card set-up. I may want to just stick to one card. Lastly, the frowning face was supposed to be an exclamation point!
ironmb View Drop Down
  Quote ironmb Quote  Post ReplyReply bullet Posted: 23 May 2011 at 12:23pm
I really can't think of a build at that budget that will have great performance for 3d rendering... Others might be able to chime in but at that budget it will be tough to get a rock solid system for that type of work.
My last system was roughly 1800$ and it struggled to render 3dMaxStudios.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 23 May 2011 at 4:30pm
Your own config won't even work, your parts won't work together.
for work kinda apps, I don't believe sli even is supported.
and again I'm no expert but I think you may need a bit more ram, not sure.
I won't get into how much better the 2600k is.
Edited by DST4ME - 23 May 2011 at 4:30pm
JStones View Drop Down
  Quote JStones Quote  Post ReplyReply bullet Posted: 23 May 2011 at 8:30pm
You need to save up a bit.  On your budget I wouldnt even be thinking about a quadro card, gaming cards have always worked great for me with personal work and Ive been in the film vfx industry for 6 plus years using maya, motionbuilder, lightwave, modo, zbrush, photoshop etc.  At work we just got bumped up to the new quadro 5000's and the difference between it and my geforce 480 back in the states is negligible.  Its pushing one dell 30" and a dell 24" by itself.  DSTME is correct I have never heard of a 3d app utilizing sli.
You say you will be using this machine for work, but how heavy is the work?
I ask because Im working in New Zealand currently and could not bring my beast with me, so I bought a cheaptastic toshiba laptop (freakin expensive over here!  $2600 for a mid range!) to do some modeling on with a geforce 330, 6 gig ram, first gen i5 and I can get by, its quite painful at times but small models (100-200k polys) can be done.
The main advantage of having a quadro is the support from the program makers for development uses.
If it were me on your budget I would save up for at least a 2600k/8gigram/560.  I know a very talented modeler who gets by with a 240, but he cant work on the really detailed stuff on it.
Edited by JStones - 23 May 2011 at 8:31pm
