Buying gaming pc need help
Post Date: 2021-01-06
mcqn View Drop Down
  Quote mcqn Quote  Post ReplyReply bullet Topic: Buying gaming pc need help
    Posted: 06 Jan 2021 at 6:07pm
hey everyone im looking at buying a gaming pc. I dont know a whole lot and this would be my first pc. i think i found a good deal online $1550 CAD which is roughly $1200 USD? i play call of duty warzone.
heres the specs, if anyone sees anything wrong or if its a bad deal let me know please......
AMD Ryzen 5 3rd Gen 3600X 3.80GHz (4.40GHz Boost)
NVIDIA GeForce RTX 3060 Ti 8GB
16GB DDR4 3000MHz
512GB SSD
Windows 10 Home 64-bit
Gaming Keyboard & Mouse
VR Ready
Gldigital View Drop Down
  Quote Gldigital Quote  Post ReplyReply bullet Posted: 06 Jan 2021 at 11:54pm
That's a good price for the specs. Usually, it's 1,200 to 1,300, so I'd say you give it a go.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 07 Jan 2021 at 6:38am
That'll work.
val View Drop Down
  Quote val Quote  Post ReplyReply bullet Posted: 06 Mar 2021 at 12:03pm
Create you help me befor on my first costom rigs 90275 need another advice from you i pass that rigs to my son now I need help with mid range gaming rigs with lumos case and costume water tubing and RTX 30 series water cool gpu i know you told me befor that the lumos case is facing the opsite side so don’t want to make choice that will not look right on it
  Quote Cretae Quote  Post ReplyReply bullet Posted: 07 Mar 2021 at 4:07am
Hi. The Velox case is the one with the glass on right side. The Lumos has glass all around, and looks good from any angle.
We need to know what you want to spend, and what monitor resolution and speed you are using. Those are the key facts. I DO NOT LIKE custom water cooling. It's not necessary for better anything; in my opinion it's just for looks. Your temperatures inside a Lumos with just the all-in-one CPU cooler and the GPU fans will be very good. I will put it in there if you must have it, but it's a maintenance headache. If it goes wrong , it's a nightmare.
Start your own thread in the CONFIGURATION DISCUSSION and tell us what your budget is and your monitor is.
val View Drop Down
  Quote val Quote  Post ReplyReply bullet Posted: 20 Mar 2021 at 7:08pm
the Monitor i have here is my Msi Optix AG32CQ 144hz freesync
see if this good set up for me this will be my gaming rigs only Load Config Digital Storm Desktop - Config ID 3827846 - SKU
Processor: Intel Core i9-10920X (12-Core) (Boost Up to 4.6 GHz)
Motherboard: MSI Creator X299 (Intel X299 Chipset) (TPM Module) (Up to 4x PCI-E Devices)
System Memory: 32GB DDR4 3000MHz G.Skill TridentZ (RGB Light Bar)
Optical Drive: - No Thanks
Storage Set 2: 1x SSD (1TB Samsung 860 EVO)
Graphics Card(s): 1x GeForce RTX 3060 Ti 8GB (Performance Edition) (VR Ready)
Add On Card: - No Thanks
Cable Management: Exotic Cable Management - Blue - (Cable Combs with Custom Color Sleeved Extension Cables)
Chassis Fans: Cooler Master MasterFan Halo (RGB Fans) (Remote Control Only)
Airflow Control: Corsair Commander PRO Management Control Board & Software (1x Board)
CPU Boost: Stage 2: Overclock CPU - Up to 4.8GHz via Intel Turbo Boost Max Technology 3.0
Graphics: Yes, Overclock the video card(s) as much as possible with complete stability
Operating System: Microsoft Windows 10 Home (64-Bit)
Mouse Pad: Digital Storm Premium Mouse Pad (Extra Large) (Full Desk) (Stitched Edges)
Keyboard: Digital Storm MasterKeys Lite Bundle (RGB) Keyboard & Mouse
Branded Gear: - No Thanks
Priority Build: - No Thanks, Ship Within 30-35 Business Days After Order Is Successfully Processed
Edited by val - 20 Mar 2021 at 7:09pm
  Quote hoserator Quote  Post ReplyReply bullet Posted: 21 Mar 2021 at 2:08am
Hi val.
Please follow Cretae's advise and start your own thread. That way you will get more posts regarding you particular needs.Strong
To the OP: good luck.Smile
Edited by hoserator - 21 Mar 2021 at 3:38am
  Quote Cretae Quote  Post ReplyReply bullet Posted: 21 Mar 2021 at 5:59am
Can't do a Config thread? This place is as hoserator said, not the right place for this.
That's not a gaming processor. The X-Series is for heavy number crunching for science or business. They are too slow for gaming, and the extra cores do nothing but cost extra.
Intel is behind the times still with the old PCIe Generation 3 platform, and I hear they are late coming with the PCIe 4 parts AMD has been offering for over a year.
The DS "Performance" M.2 is literally the slowest primary drive here. You want a 500TB Firecuda.
The GPU is underpowered for good gaming at high framerates on your monitor.
This is way better:
           3828383    $3914
The CPU/motherboard combo is my favorite for gaming. As I said, more cores is a waste of money.
You don't need the airflow control in that case, but I left it in.
You can't get overclocking on the AMD procs, you won't need it. I don't recommend overclocking the GPU, but up to you. The "tweak" to Windows is a waste of money.
ratoNty View Drop Down
  Quote ratoNty Quote  Post ReplyReply bullet Posted: 31 May 2021 at 11:40am
Thats a very good deal IMO
This page was generated in 3.222656E-02 seconds.
