Can a level 2 vanquish fit a 3rd drive
Post Date: 2019-12-09
TheElderBrain View Drop Down
  Quote TheElderBrain Quote  Post ReplyReply bullet Topic: Can a level 2 vanquish fit a 3rd drive
    Posted: 09 Dec 2019 at 9:11am
I have a level 2 vanquish and I got a ssd card for it. I current have a 4 tb and a 2 tb hard drive in the bay. I am not experienced on a high level with computers but have done all my work myself. I am trying to determine if I can squeeze a 3 rd hardrive in and where . I have a few left over cables so it seems I can, but can’t find room in the bay . The open bay near it seems too small and has no noticeable rack. Any help would be grand
  Quote Cretae Quote  Post ReplyReply bullet Posted: 10 Dec 2019 at 4:36am
I doubt the Vanquish comes like this, but newer mother boards come with 2 1/4" SSD sized slots molded into the BACK of the board. Check for that. If you don't have that feature, then know that SSDs have no moving parts. If your rig doesn't often go on safari, you can simply install one and just place it inside your case anywhere it fits without securing it, or you can get some velcro and fasten it down wherever you can. It will be safe to do this IMO.
  Quote Snaike Quote  Post ReplyReply bullet Posted: 10 Dec 2019 at 4:44am
I plan to have two SSDs stacked inside one 3.5" HD Bay... as Cretae mentioned, if you're not moving it around it will settle just about anywhere. Heck you could Velcro it to the roof if you wanted.
