Can someone help me with GPU's and consumption ?
Post Date: 2021-01-21
oxley View Drop Down
  Quote oxley Quote  Post ReplyReply bullet Topic: Can someone help me with GPU's and consumption ?
    Posted: 21 Jan 2021 at 7:40pm
Hi,
looking for configuration advise on multiple GPU's
Have the config below with 1200w power supply, but as I will be calculating proteins (BOINC team) which is using GPU, I may use more GPUs (2-3) in a near future. What is the difference between RTX3080 and RTX3090 ? Does the 3090 has something like SLI so they are both connected with some bridge ?
Does it exist for cheaper 3080 ?
The calculations actually do not care of SLI, my current system has 3 different GPU mixed Nvidia cuda and AMD and all 3 were recognized. I only had to use doohickey to pretend the monitor is connected to all of them.
Will the 1200W be enough for 2-3 RTX3080 and the PC itself ?
And what MOBO do you recommend for the future card addition ? 3 or 4 PCIE ?
Thank you
And one more Q. is 3080 or 3090 in stock ?
Processor: AMD Ryzen 9 3900X (12-Core) 4.6 GHz Turbo
Motherboard: ASUS ROG Strix X570-E Gaming (Wi-Fi) (AMD X570 Chipset) (Up to 3x PCI-E Devices)
Power Supply: 1200W Silverstone / EVGA / Thermaltake (Modular) (80 Plus Gold)
Optical Drive: - No Thanks
Storage Set 1: 1x SSD M.2 (500GB Seagate FireCuda 520) (NVM Express) (Gen4 PCIe)
Storage Set 2: 1x SSD M.2 (1TB Samsung 970 EVO PLUS) (NVM Express)
Graphics Card(s): 1x GeForce RTX 3080 10GB (Performance Edition) (VR Ready)
Add On Card: - No Thanks
  Quote hoserator Quote  Post ReplyReply bullet Posted: 24 Jan 2021 at 2:08am
Hi,
Welcome to DS.
The 3090 is the only one that can be connected with sli (Nvme). The 3080 does not accept the bridge.
The power supply is more than ample IMO but I always go for more. As to mobo, others with more knowledge will reply better. I don't think you can fill all the Pcie slots with 3080s or 3090s since they are too big.
Being a user forum, we have no knowledge of parts availability at DS insofar as to 3080 or 3090 inventory.
Good luck.
  Quote oxley Quote  Post ReplyReply bullet Posted: 27 Jan 2021 at 7:20pm
thank you. I don't need SLI, it is for CUDA cpus used for BOINC and it works well with any cards having CUDA. SLI not required, but thank you a lot.
Stellar View Drop Down
  Quote Stellar Quote  Post ReplyReply bullet Posted: 28 Jan 2021 at 8:25am
If you're running dual 3080 or 3090, highly recommend going with 1600W power supply.
