card temps
Post Date: 2011-08-03
jgarc12 View Drop Down
  Quote jgarc12 Quote  Post ReplyReply bullet Topic: card temps
    Posted: 03 Aug 2011 at 7:47pm
What are some normal card temps for you guys? I have two gtx 570s and in full load one card reads around 80c-85c and the other reads 70c-80. Would this be normal temp readings?
Thanks!
CPU: Intel Core i7 2600K 3.40GHz OCed to 4.4 GHz, Liquid Cooled
MB: ASUS P8P67 Deluxe
Memory: 8GB DDR3 @ 2000MHz
HD: 120GB Solid State Intel
GPU: 2x NVIDIA GeForce GTX 570
1.2GB
Dragoonseal View Drop Down
  Quote Dragoonseal Quote  Post ReplyReply bullet Posted: 03 Aug 2011 at 9:34pm
That with standard fan speeds? They look pretty spot on, the top card will always be a bit higher because the bottom card blocks some of its air flow.
You can tweak fan speeds with MSI Afterburner if you want, to get lower temps at the expense of higher fan noise, or just better control of the rate at which the fan speeds ramp up. I find the default fan speeds never really want to increase fast enough for me, Nvidia seems to prioritize keeping the GPUs quiet more than I do. Lilim's dual SLI 480s run a little warmer than the revised 500 series and I use a noise canceling headset so I don't hear the fans regardless, so I like a fan profile more like this:
Lilim
Intel Core i7 920 @4.2GHz
  Quote jgarc12 Quote  Post ReplyReply bullet Posted: 03 Aug 2011 at 9:55pm
Ya I have MSI Afterburner too and I have something similar to that set. I'll tweak it a little bit but it's good to know that my temps are coming out normal. Thanks for the help man!
1.2GB
