Case Fan's
Post Date: 2011-09-09
apache664 View Drop Down
  Quote apache664 Quote  Post ReplyReply bullet Topic: Case Fan's
    Posted: 09 Sep 2011 at 4:51pm
 Im looking for a way to increase my fan speeds on my case fans. Was wondering what option you guys would suggest.
Buy higher rpm fans? Or use a fan controller?
"Go Like Hell"
Cooler Master HAF 932 (Black OPS Edition)
i7 920 2.66GHz OC 3.3GHZ
EVGA X58 Classified 3X SLI
16GB DDR3
2x EVGA GTX 560 TI 1GB
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 09 Sep 2011 at 6:16pm
why do you need to raise air flow in haf? it already high airflow, are you having temp problems?
  Quote apache664 Quote  Post ReplyReply bullet Posted: 09 Sep 2011 at 10:45pm
Yes my gfx cards in sli are running a lil warm. They run about 60-65c. I use evga precision to control their fan speed in that temp range I run 85% fan to keep the temps from climbing.
"Go Like Hell"
16GB DDR3
  Quote RiceEatin2000GT Quote  Post ReplyReply bullet Posted: 09 Sep 2011 at 10:50pm
60-65 is cool for video cards.... Id lower the video card fans until it hits like 70-75c.
What kind of video cards are you running just to make sure
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 10 Sep 2011 at 2:49am
Ya 65c load is good, below 85c you are fine, above 85c is too hot.
@rice, based on his sig, its sli 560.
  Quote RiceEatin2000GT Quote  Post ReplyReply bullet Posted: 10 Sep 2011 at 2:52am
such a noob mistake lol
  Quote apache664 Quote  Post ReplyReply bullet Posted: 10 Sep 2011 at 10:32am
Ok, good to know, thanks for the info guys! Awesome
"Go Like Hell"
16GB DDR3
ablahblah View Drop Down
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 10 Sep 2011 at 5:13pm
Also..I don't believe you can raise a fan above its 12v speed, unless you crank it up above 12v. Dunno if most fans can take over 12v. You can decrease speeds by undervolting though.
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 10 Sep 2011 at 11:44pm
Our pleasure and good luck
