Case Fan Direction Hailstorm
Post Date: 2012-07-28
kjk72 View Drop Down
  Quote kjk72 Quote  Post ReplyReply bullet Topic: Case Fan Direction Hailstorm
    Posted: 28 Jul 2012 at 7:56am
Have had my rig for a couple of years and now need to change one of the fans on the top of the case (800D).  Never really thought about the flow direction of the case fans.  The top fans blow into the case.  The bottom fan blows into the case.  The rear fan blows out.  Is this the correct airflow?  Config is below.  Thanks.
Chassis Model: Digital Storm HailStorm (Black OPS Edition)
Processor: Intel Core i7 Extreme Edition 980X 3.33GHz (Hexa-Core) (Extreme Performance)
Motherboard: EVGA X58 Classified 3X SLI (Intel X58 Chipset) (Supports Triple SLI or CrossFire)
Hard Drive Set 1: Operating System: 1x (256GB Solid State (By: Corsair) (Model: CMFSSD-256GBG2D)
Hard Drive Set 2: Multimedia\Data: 1x (2TB Western Digital (7200 RPM) (64MB Cache) (SATA) (Extreme Speed WD2001FASS 2TB)
Video Card(s): 2x CrossFire Dual (ATI Radeon HD 5870 1GB)
Extreme Cooling: H20: Stage 6: Sub-Zero LCS Dual Loop: CPU & Dual SLI/CrossFire Video Cards
H20 Tube Color: Red Tubing with High-Performance Fluid (UV Lighting Reactive)
CPU Boost: FREE: Stage 1: Overclock the processor between 3.3GHz to 3.9GHz (Requires Air Cooling Upgrade)
Memory Boost: Memory Fan Kit Only (Does not include memory overclocking service)
Pre-Install Game: FREE: Please include a free copy of a hot-selling game
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 28 Jul 2012 at 8:05am
When DS tested the rig they probably found the top fans blowing fresh, cool outside air over the rad worked best.   The heated air from inside the case might give the rad less cooling potential.   I would leave it with top fans blowing in.
Some cases with better air cooling with larger fans and more of them would probably work either way, but the 800D only has the single 140mm blowing in from the bottom.
There has been some discussion about whether to blow out to give the case better airflow or in to supply the rad with better air.  DS did the testing so I'd stick with it , in my opinion.
  Quote kjk72 Quote  Post ReplyReply bullet Posted: 28 Jul 2012 at 8:13am
Thanks.
surf71zx View Drop Down
  Quote surf71zx Quote  Post ReplyReply bullet Posted: 01 Aug 2012 at 7:59pm
Go to performance-pcs.com for any kind of case fan you could want. Huge selection.
