Changing hard drive configuration.
Post Date: 2011-08-28
Locutus494 View Drop Down
  Quote Locutus494 Quote  Post ReplyReply bullet Topic: Changing hard drive configuration.
    Posted: 28 Aug 2011 at 4:07am
I bought my Digital Storm Black OPS Hailstorm (Corsair Obsidian 800D case) with 2 SATA III hard drives. When I received my system I found that Digital Storm had not connected the hard drives to the SATA III ports, using the SATA II ports instead. I tried to change the hard drives to the SATA III ports, but I got all sorts of errors and BSODs, so I put them back the way they were.
Do I have to reinstall Windows to change which ports the hard drives are connected to, or are my problems caused by something else? FYI: My 800D case does have the SATA III upgrade for the hot swap bays.
Dragoonseal View Drop Down
  Quote Dragoonseal Quote  Post ReplyReply bullet Posted: 28 Aug 2011 at 6:07am
There is no such thing as a SATA 6Gb/s HDD. Unless you meant a SSD? No conventional HDD comes even remotely close to maxing out the bandwidth of a SATA 3Gb/s port, so there is no reason to have them clogging up a SATA 6Gb/s port (save them for SSDs), so DS was correct in doing that.
What HDD and motherboard are even talking about here? If it is a P67 motherboard then there are 2 Intel SATA 6Gb/s ports and 4 Intel SATA 3Gb/s ports. Some P67 motherboards additionally have 2 Marvell SATA 6Gb/s ports tacked on, or at least they're advertised as such but in reality their performance is god awful bad and you want to avoid using them at all costs as long as you still have Intel 6Gb/s or 3Gb/s ports free. If it is a X58 motherboard then it has 6 Intel SATA 3Gb/s ports. Some X58 motherboards additionally have 2 Marvell SATA 6Gb/s ports tacked on, same deal avoid them.
If your HDDs were installed using Intel ports then I highly doubt you can just plug them into the Marvell ports, they aren't configured for it. Same thing if you have Windows installed under AHCI mode and then switch the motherboard over to IDE, you won't be able to boot because only the AHCI drivers are installed, and vice versa. However if you are just switching from an Intel port to a different Intel port I wouldn't think there would be a problem, but I could be wrong.
Lilim
Intel Core i7 920 @4.2GHz
  Quote RiceEatin2000GT Quote  Post ReplyReply bullet Posted: 28 Aug 2011 at 2:55pm
i had something similiar done on my computer when i got it. I had a crucial c300 ssd plugged into the god awful marvel ports. I simply unplugged and moved over the ssd and the wd black over and everything was fine.
I was losing around 30-40% performance on my ssd because it was on the marvel ports.
  Quote Locutus494 Quote  Post ReplyReply bullet Posted: 29 Aug 2011 at 1:56am
I have an EVGA X58 Classified 3 (141-GT-E770-A1). The spec sheet says the SATA III ports use the Marvell 9128 controller. Are those the bad ones you're talking about? What makes them so bad?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 30 Aug 2011 at 4:22pm
Unless you got a drive that has speeds that max out sata 2 don't worry about sata 3.
yes those are marvell and you want to stay away from them as they will hurt your performance.
