Changing lighting withoute remote?
Post Date: 2020-07-02
AudreyXO View Drop Down
  Quote AudreyXO Quote  Post ReplyReply bullet Topic: Changing lighting withoute remote?
    Posted: 02 Jul 2020 at 2:50am
Hi everyone! Long time DS fan here. :) I just upgraded from my old DS PC by getting a pre-owned one with better specs, but it didn't come with the remote. It's the Lumos.  I was wondering, is there a way to change the lighting? If not, is there a way to buy the remote separately? I'm kinda bumming because the light inside is red, and I'd love to change it to blue. Thanks!!! Love
  Quote Cretae Quote  Post ReplyReply bullet Posted: 03 Jul 2020 at 4:13am
If we're talking about the internal light strip, it wouldn't hurt to ask DS if you could get ahold of a remote. You may have to buy the light strip to get it.
An alternative could be to go shopping online. It's likely DS doesn't have te only colorful light strip in town, and you may decide you prefer some RGB fans instead. Fans are pretty easy to replace.
