chassis airflow option
Post Date: 2010-11-20
xhui View Drop Down
  Quote xhui Quote  Post ReplyReply bullet Topic: chassis airflow option
    Posted: 20 Nov 2010 at 8:28pm
if i select the upgrade chassis airflow that up to 6fans, do DS replace the fans it come with the case? or just add more fans the optional fans slot? both?
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 20 Nov 2010 at 9:04pm
dont choose it
and to answer your question, they replace all from what i understand
again to reiterate, dont choose it.
xhui View Drop Down
  Quote xhui Quote  Post ReplyReply bullet Posted: 20 Nov 2010 at 9:16pm
why?...is it not more air flow always better? since im going to OC both gpu and cpu
Edited by xhui - 20 Nov 2010 at 9:18pm
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 20 Nov 2010 at 9:49pm
nope, this is all covered in the guide linked in my signature, long story short, good cases already cool themselves well and quietly
its not cost effective and its unnecessarily loud as they use all 120mm fans
maxyme View Drop Down
  Quote maxyme Quote  Post ReplyReply bullet Posted: 21 Nov 2010 at 3:20pm
if you want more fans i would research them and buy them yourself. then you can get really good fans and everything. plus fans are the easiest part to upgrade in a computer.
Steam:pcmaster160
