Cleaning help!
Post Date: 2013-11-12
Burr View Drop Down
  Quote Burr Quote  Post ReplyReply bullet Topic: Cleaning help!
    Posted: 12 Nov 2013 at 9:12pm
Hi,
I was curious as to whether or not there is a specific way, that's recommended, to clean the 120mm Liquid CPU Cooler on my ODE lvl 2?
My CPU temps are great, but there is a constant clicking sound coming from one of the fans, and it tends to bother me, haha. I assume the clicking would be due to dust build up, as it never occurred when I first received my ODE lvl 2.
Thanks.
  Quote fstcvc Quote  Post ReplyReply bullet Posted: 12 Nov 2013 at 11:12pm
If you haven't already done so, use compressed air to remove all dust from the fans and radiator. If the clicking sound continues, you might have a bad bearing on the fan and have to replace it. I believe you should be able to use any standard 120mm case fan as a replacement.
This page was generated in 4.394531E-02 seconds.
