Clueless - looking for configuration help
Post Date: 2020-12-17
bfooj View Drop Down
  Quote bfooj Quote  Post ReplyReply bullet Topic: Clueless - looking for configuration help
    Posted: 17 Dec 2020 at 10:32pm
Hello!
So I've been interested in the Lumos (sucker for RGB lighting) for awhile now and I've read up on configurations for my budget on the forums and came up with the one below. Any suggestions on changes would be appreciated! Open to either processor. Thanks in advance for your help!
I have an Asus VG245H 24"Full HD 1080p monitor, plan to get an additional monitor
[~$2500]
[Looking for a dependable computer that will need minimal upgrading and will last a good while and being able to have the capabilities to run whatever I want at max settings]
[Gaming/Streaming/general everyday use]
Saved Ticket #: [3654224]
Processor: Intel Core i7-10700K (5.1 GHz Turbo) (16-Thread) (8-Core) 3.8 GHz
Motherboard: ASUS TUF GAMING Z490-PLUS / MSI MPG Z490 GAMING EDGE (Intel Z490) (Up to 3x PCI-E) (No SLI)
System Memory: 16GB DDR4 3000MHz Corsair Vengeance RGB Pro (RGB Light Bar)
Optical Drive: - No Thanks
Storage Set 1: 1x SSD M.2 (500GB Samsung 980 PRO) (NVM Express)
Storage Set 2: 1x SSD (1TB Samsung 860 EVO)
Graphics Card(s): 1x GeForce RTX 2060 6GB (VR Ready)
Airflow Control: - No Thanks
Mouse Pad: - No Thanks
Branded Gear: - No Thanks
Edited by bfooj - 17 Dec 2020 at 11:57pm
  Quote Cretae Quote  Post ReplyReply bullet Posted: 18 Dec 2020 at 4:48am
If you substitute in the RTX3060 Ti, your net after discount is $2520. A better GPU is always a good idea in a gaming rig, if it can fit the budget.
If you built those same parts into a Lynx case, you could get an RTX 3070, and get the lights for free. AND SAVE MONEY! $2201 after discount.
     Config #   3654594
Just sayin'.
  Quote bfooj Quote  Post ReplyReply bullet Posted: 22 Dec 2020 at 9:14pm
     Config #   3654594
Just sayin'.
@Creatae - thanks for the reply! I prefer the Lumos case over the Lynx, but could you provide a comparable AMD configuration? I've noticed you've suggested going AMD in other posts.
Edited by bfooj - 22 Dec 2020 at 9:19pm
  Quote Cretae Quote  Post ReplyReply bullet Posted: 23 Dec 2020 at 4:34am
Sure!
   Config #   3667321     $2512 after discount
This build is designed with parts I believe to be available right now. I put in the Firecuda vs the Samsung 980 as it saves $42 and the 980 has been in short supply just recently. You will never know the difference.
The MSI gaming Pro carbon is my current favorite motherboard.
If you want to wait indefinitely, you could try for a 5800X, but the 3800X will last and last and not gimp this build.
  Quote bfooj Quote  Post ReplyReply bullet Posted: 31 Jul 2021 at 9:10pm
Sure!
@Cretae - Unfortunately I did not end up pulling the trigger back on the my original inquiry. With the recent reveal of full time work from homer conversion for my work, I'm even more in the market for a reliable computer. As parts have changed from my last inquiry, I was wondering if you could possibly provide me with an updated configuration similar to the last with updated parts? Any input is much appreciated!
  Quote Cretae Quote  Post ReplyReply bullet Posted: 01 Aug 2021 at 7:29am
Over time the prices have changed, and the 3060 Ti is backordered. For $60 over the 3060, that is a supercard, but the 3060 will beat the heck out of the 2060 you originally budgeted, and game very well at 1080p. You've been patient to this point, so I would order the 3060 Ti.
Here's the best equivalent to what I recommended for you back in December:
    Config # 4010016   $2985.
There's no discount (damn!), the 500GB Firecuda has gone away, and the GPUs are pricier. The GPU is gonna delay you some. Check with DS as to how long. You can mix/match/play with this build, and bring the cost down some, about $260 if you get the 3060 and ditch the RGB fans.
Here's another build that will be nearly as good and preserve some of your wish list:
    4010021    $2455
The 5600X is 6 cores, but it is no slouch at all for gaming. The Intel "equivalent" (i5-10400F) here is a PCIe Gen 3 part you do not want. The 5600X has great reviews from all over. The 8 core 10700K you originally were looking at is a mere 5% faster, but it's also obsolete PCIe gen 3. The AMDs are all Gen 4. That's double the bandwidth.
Still have the Gaming Pro Carbon, but it's not essential. you could easily sub in the base Asus or MSI motherboard which are not slouches at all. I like a little bit of upgrade here when it doesn't cost the farm. My bias is the better the board, the more they put into heat management, so it just might last a little longer. It might be nice to have Wi-Fi.
The Primary has to be the 500GB 980 PRO which is faster and preferable to the Firecuda anyway. I gave you all SSD storage. Yeah, it's 1 TB less, but about 7 times faster. It's easy to add another SSD when you need one, and much less expensive online.
The GPU only saves $60, but there's the time factor. The 3060 is just 8% behind the older 2070, which was what we recommended for 1440p gaming on a budget. The 3060 Ti, however, is 33% faster than the 3060! It barely edges out the base 2080 (NOT the SUPER, NOT the Ti) from last gen that's how good it is.
The Lynx case is for the budget. You get RGB included at about $300 less than RGB fans in a Lumos.
These are some tough choices. It all comes down to how much you want what you want. The "compromise" system will game your socks off for several years, and is fully upgradeable. CPU, GPU, RAM, storage. If the Lumos is your thing, let the fans go for now, and add them as a fun-ish DIY when you've got the cash.
