Comments on my proposed system
Post Date: 2008-10-11
grantross View Drop Down
  Quote grantross Quote  Post ReplyReply bullet Topic: Comments on my proposed system
    Posted: 11 Oct 2008 at 9:19pm
I'm am considering the system below and would like some feedback.  This is my first time buying a custom system.  I am new to gaming but have always had a week spot for electronics, computers, audio/video.  Let me know your thoughts.  Any item needed upgraded or is something excessive?
Thank you!
Chassis: Digital Storm 950Si
Power Supply: 1200W PC Power & Cooling (Turbo-Cool Edition) (Dual/Triple/Quad SLI Compatible)
Processor: Intel Core 2 Quad Q9650 3.0GHz (1333MHz FSB) (12MB Cache)
System Memory: 4GB DDR3 1600MHz Corsair DHX (High-Performance)
Video Card: NVIDIA GeForce GTX 280 1GB (Includes PhysX Technology)
Modifications: NVIDIA Enthusiast System Architecture (ESA) System (Install, Test, Optimize Computer)
Restore Kit: Digital Storm Specialized Recovery System (DVD Image Based)Warranty: 3 Year Platinum Care Extended Parts & Labor Warranty
  Quote RiceEatin2000GT Quote  Post ReplyReply bullet Posted: 11 Oct 2008 at 9:31pm
i would look at the differences from vista ultimate vs home 64(there really isnt alot of different things)  I would also say since your spending this amount of money it may be beneficial to get a velicraptor
Edited by RiceEatin2000GT - 11 Oct 2008 at 9:39pm
  Quote RiceEatin2000GT Quote  Post ReplyReply bullet Posted: 11 Oct 2008 at 9:41pm
I agree with Rice above...Look at the V-Raptor...
You have a hugh PSU..Planning to SLI later?
Its a nice solid build.......The main advantage of Vista Ultimate is that you can burn a backup to disk not just a drive..And extra games.....
Dead if you dont plan on going SLI in the near future and cant spend any more money i would sooner get rid of the overkill PSU and pick up the better drive for now.  You can always gets the PSU when you go SLI if you dont mind swapping it out
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 11 Oct 2008 at 9:43pm
can I get youe budget please, and your ticket number.
welcome aboard you are at the right place.
  Quote grantross Quote  Post ReplyReply bullet Posted: 11 Oct 2008 at 9:46pm
Thank you for the feedback.  I am trying to stay under $4k for my budget.
Ticket Number: 193934
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 11 Oct 2008 at 10:00pm
this is a beast, you can add another 280 gtx in there.
here you go Ticket# 193944 --- Price: $3384 (To see this build click here)
Raid Option: - No Thanks
Hard Drive 3: - No Thanks
TV Tuner: - No Thanks
Modifications: - No Thanks
Protection: - No Thanks
LCD Display: - No Thanks
now what resolution are you gonna be gaming at?
Edited by DST4ME - 11 Oct 2008 at 10:01pm
SunfighterLC View Drop Down
  Quote SunfighterLC Quote  Post ReplyReply bullet Posted: 11 Oct 2008 at 10:28pm
Yea gotta know the max rez of your monitor first before people can say really if the GPU you need is the one you should get.
Plus keep in mind your 1200W power supply is enough for 3 GTX 280s. So you better plan on adding a card later or two later otherwise you overspent in that field of play =P
E8500@ 4.03Ghz
XFX 790i Ultra
1000W Corsair HX
2 280 GTX EVGA FTW
4GB OCZ Reaper 1800Mhz
250-80-300GB VR HD
Logitech Z-2300 2.1 Speakers
Asus Xonar 7.1
  Quote grantross Quote  Post ReplyReply bullet Posted: 12 Oct 2008 at 9:34am
Couple other questions:
1.  Do the diferent chasis' allow for different configurations?  Outside of the number of bays and the air flow, why would I pick HAF932 versus the 950si?
2.  I need to upgrade my monitor.  I'm considering the Gateway XHD3000 Monitor (30-inch); max resolution is 2560 x 1600.  It'll be a couple months after I get this PC though.  Is this setup a good fits for this monitor/resolution?  Any other suggestions for monitors?  More bang for buck?
Thanks!
  Quote grantross Quote  Post ReplyReply bullet Posted: 12 Oct 2008 at 9:55am
Also, is the price differential jumping to one of the extreme processors worth the gain?  Would I notice the difference?  If I want to hang on to this PC for at least 4 to 5 years, is it worth jumping up?   Any new processor coming out soon that I should wait on?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 12 Oct 2008 at 4:16pm
yes there is a new processor comeing out and I think the prices will drop.
HAF can hold totall of 11 drives, and for the money its a great case .
as for waiting for the new one or jumping higher, thats a personal decision, all I can tell you is that I'm waiting
Edited by DST4ME - 12 Oct 2008 at 4:16pm
