Comp not starting
Post Date: 2010-09-27
nmankoci View Drop Down
  Quote nmankoci Quote  Post ReplyReply bullet Topic: Comp not starting
    Posted: 27 Sep 2010 at 10:19pm
So, i go to turn my comp on, and it says my cpu has been reset. Gives me an option to press F1 to continue of go into bios. I press f1, and screen goes black. Turn it off, I unplug the cord from the wall after turning the power switch off. I plug everything back in and turn switch on. I then turn the comp on. The mobo power cycles once, then back to showing me the screen that tells me my cpu reset. I don't know what to do.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 28 Sep 2010 at 8:20am
how long have you had the computer?
did you already go through the techincal assistance guide in the technical assistance section?
  Quote nmankoci Quote  Post ReplyReply bullet Posted: 28 Sep 2010 at 10:25am
Actually, i never saw the guide. After I read it, it started up. However, I lost my overclock of 3.9ghz. It's back down to 2.8:(. So, thanks for the guide, It eased my trouble
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 28 Sep 2010 at 11:11am
did you have your bios settings saved?
what part of the guide did you do to have it start up? did you reset the bios?
  Quote Alex Quote  Post ReplyReply bullet Posted: 28 Sep 2010 at 1:45pm
The overclock settings may still be saved in a Overclock profile. If not, feel free to contact us and we can help you out.
This page was generated in 3.613281E-02 seconds.
