Complete Liquid cooling system
Post Date: 2010-04-17
Ambidex View Drop Down
  Quote Ambidex Quote  Post ReplyReply bullet Topic: Complete Liquid cooling system
    Posted: 17 Apr 2010 at 7:52am
Hello guys
I need help about the parts for my system.
First my specs:
Corsair Obsidian 800D (Hailstorm)
EVGA X58 3x SLI Classified
I-7 920
Sapphire HD 5870
Corsair Dominator 1600 MHz (3x2Gb)
Corsair HX 1000W
LG LED Flatron W2486L 2ms, 24".
HDD is irrelevant
I want the following stuff water cooled:
Motherboard: Chip set & the other thing(forgot name)
CPU
GPU
(I see no reason to water cool the RAM)
I was thinking of complete koolance parts.
Is this more expensive?
If someone could give me an approximate price range of what it will cost, and maybe the different price ranges that the different brands would give. I pretty much want the kick ass ones, I think koolance is the one to go with.
So if someone could just give me the list of all the parts I need. I would really appreciate it.
I want white hoses.
I'm not a fan of flashy stuff. So a black & white combo would be nice.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Apr 2010 at 6:23pm
are you planing on building this LC system yourself or from DS?
ocing the mobo is pointless. just oc the cpu and if you really need it the gpu, otherwise the gpu is not necessary either.
koolance is definitely not the way to go.
ablahblah View Drop Down
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 17 Apr 2010 at 6:31pm
aight...first, understand how massive liquid cooling's cost is...
I've managed to construct a pretty decent CPU loop, and the lowest price I can get the whole setup to be is $308. that's JUST for the CPU. if you add on GPU and mosfet, you'll probably have a $500 system.
if you want DUAL LOOP, one for the cpu/mosfet, one for the GPU, you're looking at about a $800 or more setup.
(I second what DST4ME says, cooling the mobo is pointless, as well as overclocking RAM)
so, are you sure you're ready to spend this much?
For brands, here's some tips I've acquired
-NEVER EVER USE THERMALTAKE
-Swiftech makes pretty damn good CPU waterblocks (see Apogee XT)
-Koolance seems to make pretty decent quick releases
-Danger Den usually offers part constructions where you can't find them anywhere else
First off, I need to know. Do you want a loud but effective system, or a quiet, low profile system? And, do you want kick-ass, or cost-effective, or somewhere in between?
(A thing to note about low profile rigs - Having a kick-ass cooling system usually means mounting an exterior radiator, which doesn't always look too appealing from the behind, heh. what? I'm an aesthetics guy)
ALSO. How big of an overclock do you want?
Edited by ablahblah - 17 Apr 2010 at 6:36pm
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote Ambidex Quote  Post ReplyReply bullet Posted: 17 Apr 2010 at 7:40pm
I want a 4Ghz overclock
And I want a one thats inside the case.
CPU with 3xradiator is what I want too.
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 17 Apr 2010 at 7:50pm
aight, so you were planning to mount the CPU rad on the top exhaust, right? that's doable...
now...for the GPU...your only other exhaust fan is your fan on the side....it's a bit risky to use all your fans for exhaust/radiator, but it's doable i guess...
do you want quick releases? (it'll bump up your pricing at least $150 or so)
do you want quiet and low profile, or possibly loud but kickass?
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote Ambidex Quote  Post ReplyReply bullet Posted: 17 Apr 2010 at 8:59pm
kickass
150 is ok
3x rad in the top
  Quote Ambidex Quote  Post ReplyReply bullet Posted: 17 Apr 2010 at 9:07pm
And IF you could teach me to overclock my i7 920 that would make my day lol! :D
I so want to overclcok it! I now have a h50 cooler.
venom View Drop Down
  Quote venom Quote  Post ReplyReply bullet Posted: 17 Apr 2010 at 11:19pm
4GHz you can get on that H50, currently mine is at 3.9GHz on an H50.
To be honest unless you have tons of cash to throw away, I wouldn't bother watercooling the system at all.
A single loop CPU + GFX is going to be around $500-$600 depending on brands, what type of tube, what type of barbs, etc.  Personally I would get another 5870.
Edited by venom - 17 Apr 2010 at 11:22pm
  Quote Ambidex Quote  Post ReplyReply bullet Posted: 18 Apr 2010 at 12:17pm
I have tons of cash to throw away. So it isn't really a problem lol.
I want to water cool the chip set because it looks cool. I want white tubes, and white fans, no lights though.
So, north bridge & south bridge, and the opther mobo chip thing + cpu would be the best. (With 2x 5870 air cooled)
  Quote Ambidex Quote  Post ReplyReply bullet Posted: 18 Apr 2010 at 12:24pm
Teach me how to overclcock my i7-920 to 4GHz please. NO one ever answers on thiese forums to do it. And I don't trust those videos on youtube.
Zimbawan View Drop Down
  Quote Zimbawan Quote  Post ReplyReply bullet Posted: 18 Apr 2010 at 12:27pm
Post a topic in the Performance/Overclocking thread.
  Quote Ambidex Quote  Post ReplyReply bullet Posted: 18 Apr 2010 at 2:03pm
Zimbawan stop destroying my thread and read it before doing stuff like that.
  Quote Zimbawan Quote  Post ReplyReply bullet Posted: 18 Apr 2010 at 2:48pm
I don't see how I am "destroying" your thread... just figured it would be better to make a separate post in the appropriate thread for the overclocking portion. I don't know enough about the liquid cooling components to guide you there.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 18 Apr 2010 at 3:29pm
he is right, a seperate thread is best, justin will probably be the one to help you if he has time, I'm not as good and I don't know how he has the patience to go thru so many pages of posts, for me if the pc is not in front of me I don't want to mess with it, plus justin is a benchmarker and not just any, he is one of the top guys so he knows how to oc best better then many many people, including myself, I have not even had a chance to mess with i7 yet.
so in short post a seperate thread and ask justin to help you, he has template he posts for everybody he helps so that they can post their bios settings, read of those threads that is asking for help in oc, you will see justin post the template and ask the user to fill it, get that template and post it in your thread with your bios settings, so that its easier on him.
of course you can always call DS and ask them to help you get to 4GHz also.
  Quote Ambidex Quote  Post ReplyReply bullet Posted: 20 Apr 2010 at 12:38pm
Well I have written 2 posts withing 3 months, and Justin has never answered my threads... :S
What can I do lol
AndydViking View Drop Down
  Quote AndydViking Quote  Post ReplyReply bullet Posted: 20 Apr 2010 at 3:28pm
@Ambidex if Justin is busy you might try the EVGA forums too.  They have a lot of knowledgable people willing to help others with EVGA boards.  On their X58 mobo section their is a few overclcoking guides that are really worth reading just so you get the idea of what someone that is helping you will be asking you to do, with settings and so forth.
Also, like Venom said you can go pretty high on the cooler you have with push/pull and spend a ton less or put that money into different areas.  Alot of people on the EVGA forums have that H50 cooler and really like it.
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 20 Apr 2010 at 5:22pm
The real only reason you wouldn't go with an H50 is that if you wanted a freaking insane overclock at +4. The H50's single rad is usually enough to net a 3.8Ghz, building your own LC loop for about $300 more just to add an extra radiator will net you about a 4.2 overclock or so.
In addition, I read in your other thread that your 920 isn't OC'd at all. Most CPUs come out of the factory at a slow speed so it can fit every application and be stable. Big, spacious gaming PCs often have a crapload of airflow, so they're usually capable of getting a nice overclock without any cooler modifications at all.
Also, is the reason you want liquid cooling because your computer is too slow? If so, describe what exactly you mean. If programs that are opened up simply run slow after they open up, then you might be on the right track. However, if startup is slow, or programs and games open up slow, then you probably just need a hard drive upgrade. The hard drive speed is often completely overlooked, and having a superior SSD will boost performance greatly.
Edited by ablahblah - 20 Apr 2010 at 5:24pm
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote Ambidex Quote  Post ReplyReply bullet Posted: 20 Apr 2010 at 7:30pm
The pc isnt slow. Jsut want it cooler. And looking better. :)
Sapphire HD 5870
Corsair Dominator 1600MHz 6Gb
Corsair HX 1000W
LG LED w2486L 24" 2ms,1mill:1
Swiftech custom liquid cooling
Corsair GT 120GB
  Quote <8) slunK parade Quote  Post ReplyReply bullet Posted: 20 Apr 2010 at 9:46pm
pray that the god justin blesses you with knowledge of the overclock
or try sacrificing a cpu while chanting his name
Raif View Drop Down
  Quote Raif Quote  Post ReplyReply bullet Posted: 26 Apr 2010 at 1:54am
lololololololololololol
2.5 Ghz Core duo
Nvidia 9500 gt
3 gb 1033 Mhz ram
[email protected]
This page was generated in 5.566406E-02 seconds.
