Computer Problems
Post Date: 2012-03-15
Vladmar View Drop Down
  Quote Vladmar Quote  Post ReplyReply bullet Topic: Computer Problems
    Posted: 15 Mar 2012 at 3:01am
Alright, I have already RMA'd my PSU, and Motherboard to Digital Storm. Just got everything hooked up. Computer turns on but I was getting no beeps from the motherboard so i removed all the RAM to see if i got another faulty mobo. The motherboard let out 1 long beep followed by two short beeps which means there is no RAM installed so at least i know it's not the mobo. It's not the PSU, just got a new Corsair GS800 from DS as well. This leaves two possible culprits, either I have bad RAM (maybe, not sure about though) or a bad GPU. I'm pretty certain it's not my cpu because my mobo is not displaying a bad cpu light but that doesn't fully rule it out. When I plug my PCIE cables into my GPU (ASUS DirectCU II 6950) and boot up my system, my computer will die after about 1 second. Then it will come back on and my cpu fan will go nuts. It has to be spinning at full RPM. So, I shut down my computer and unplug the pcie cables from my gpu and everything spins up normally, no abnormal sounds or fan spinning. I still get no video or beeps from my mobo but I know the mobo is working. What could this be? I'm thinking it's a bad gpu because just by process of elimination that seems like the only thing it could be. I'd appreciate any comments Thanks.
i5 2500k
8GB A-DATA 2000mhz DDR3
ASUS P8P67 REV 3.1
ASUS DirectCU II Radeon 6950
Corsair GS800
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 15 Mar 2012 at 4:31am
Hi Vladmar.....Sorry to hear of the problems.  It could still be the psu, new or not, the psu dying under load..  It could be a bad pci slot on mobo, so try putting the gpu in another pcix16 slot and see if it at least boots up fine.  Not using pci slot one might cause a bios message, not sure.
Try one ram stick at a time.
And, it could be the gpu.  Cry  Do you have an old one lying around you can try??
No easy answer..  Let us know.
Edited by bprat22 - 15 Mar 2012 at 7:06am
