Config. Help and suggestions
Post Date: 2008-02-10
Hunter View Drop Down
Guest
Guest
  Quote Hunter Quote  Post ReplyReply bullet Topic: Config. Help and suggestions
    Posted: 10 Feb 2008 at 4:15pm
Hey all,
Im looking at getting a computer that can handle games well and be readily upgradable. I chose a small built in HDD because im going to store most things on a portable HDD I keep with the computer. I can get RAM and GFX cards on the cheap through my work, so I downgraded those in order to save on costs.
I have two questions regarding this configuration though. One, given the MB, what Hz RAM can I get that will give me the best performance but not be faster than the MB can really use. And secondly, what is your guys personal opinion between stepping up from an 8800GTS to the GTX?
Any and all help would be really appreciated, and if you have anyways to further alter the configuration for the smoothest (and quickest) operation of this rig please let me know. Thanks.
Configuration:
Case: Digital Storm Twister LITE (Black Aluminum Edition)
Power Supply: 750W SilverStone Olympia (Dual SLI Compatible) (Model: OP750) (Silent)
Processor: AMD Athlon X2 5600+ 2.8GHz (Dual Core) (2 MB Cache) w/HyperTransport
Motherboard: Asus M2N-E SLI (nForce 5 series SLI Chipset)
Memory: 1GB DDR2 Corsair at 667MHz
Floppy / Card: - No Thanks
Hard Drive 1: 160GB Western Digital (16MB Cache) (7200 RPM) (SATA)
Hard Drive 2: - No Thanks
Raid Option: - No Thanks
Hard Drive 3: - No Thanks
Video Card: nVidia GeForce 7200GS 256MB (By: eVGA) (PCI-Express)
TV Tuner: - No Thanks
Sound Card: Motherboard Multi-Channel High Definition Audio (7.1 Channel)
Physics Card: - No Thanks
Cooling: Air Cooled Stage 2 (Silent Artic Cooling Heat-sink (Copper Heatpipes)
Case Lighting: Blizzard Internal Lighting (Green Edition) (Cold Cathode Tubes)
Round Cables: - No Thanks
Tweak Windows: Yes, Disable and tweak all of the non-crucial services on the operating system
Protection: - No Thanks
Pre-Install Game: - No Thanks
LCD Display: - No Thanks
Solo View Drop Down
  Quote Solo Quote  Post ReplyReply bullet Posted: 10 Feb 2008 at 4:17pm
I would just like to say, I stored everything i had on a portable HD to save space on my computer, over 400GB of pictures /videos/music/everything.
The HD died.  Lost everything :(
Solo View Drop Down
What is your budget?
You could def downgrade your PSU as well.
Edited by Solo - 10 Feb 2008 at 4:20pm
Guest
Guest
  Quote Hunter Quote  Post ReplyReply bullet Posted: 10 Feb 2008 at 4:23pm
IM trying to keep things as close to about $1100 as possible, but am open to ideas that may cost more but would be a good improvement. I'll keep the crashed HDD in mind, thanks.
